R class future
R proves itself yet again...
The funny part here is that once again the R is generating alot of discussion. It's rather hard to define or pin down...and this is why it was designed and built - to create a new "class" of vehicle in the market. Regardless of what it is ... it's been my smartest purchase ever. Just drove back through the "cowboy trail" on the weekend through some mountain ranges - beautiful scenery - twisty road - and four passengers with two hockey bags - all oblivious to me doing 170 Km/h. Can you say 'multi-purpose?'
Don't forget about the high end drive train (motor, trans, 4matic) under the skin. R is now cheap like borsche (not porsche). And everyone else will silently think you're rich.
Just do it.
Just do it.
1 Post
2008 R350 & 2008 C300
After testing both the GL and R, the R has a slightly more cramped third row. Because the GL is taller, it has a taller leg room area above the rear differential. This allows your legs to sit flatly on the third row's cushion rather than the R, your knees are above the cushion. R has a curved headroom area which means less room, and the new 09 has cheaped out rear armrests that are now hard plastic instead of leather. The GL is appointed better with the leather dash, door panel inserts, and third row armrests. Just my $0.02
@chilledbenz,
Yeah, I realize the R is cheaper, but that wasn't my point. My point was the interior is slightly nicer. Shame no Rs have the V8 anymore.
2005 C230 Kompressor
We still have the R500 hardmarks for the rear on the assembly line(thats one of the stations I do) and we also have a R550 hardmark(that I have yet to use). They may not be available at the moment but they(being MB) havent removed them from the assembly line for a reason.....IMHO.
#32
as for interiors, i've seen the GL's and ML's, and imho they are not nicer than R's. also, regardless of what the specifications say, the R class 2nd and 3rd row have more room than the GL's.
Patrick
#34
1 Post
I climbed into the third row of both and found the R class to have more room as well.
I also found that if the GL isn't equipped with memory seats, you have a heck of a time trying to even get into the third row. If it has memory seats you just pull the lever for the second row and the front seat will move forward automatically, allowing the second row to tilt all the way forward. The problem arises when the GL isn't equipped with memory seats, because when you pull the handle to flip the second row forward it will hit the front seat not allowing access. Only when the person sitting in the front seat moves their seat forward and allows the second row to flip forward will you be able to even get into the third row. Although the memory seat option is part of the P1 group and lets face it, all GL's will have P1 unless you special ordered.
The R class isn't without problems either. When you pull the handle to flip the second row forward the head rest will hit the front seat, hence you must remove the head rest, or squeeze into the third row. Its not really that much of a squeeze, cause I've done it myself, but its much easier without the head rest in place. For me its much easier to remove a head rest than to have the person in the front seat have to readjust their seat every time someone wants in the third row.
I do like the GL's slick power fold option for the third row though. It's nearly impossible to fold the third row seat in the R class from the hatch area, a power button would be nice. The GL third row also folds flat into the floor without the rear cushions popping up, which is also a nice touch.
But in the end, I wouldn't want to spend any long amount of time in either third row, which makes the R class second row all that more inviting. If you slide the second row all the way back you could easily install some Maybach recliners back there for some real nice motoring ha ha.
#37
make the rear doors automatic
I bet if MB made the rear doors automatic somehow, their sales would soar.
I know a good amount of minivan owners who said that's the one thing that prevented them from buying the R...and after owning the R, while i love it, I know what they mean.
#38
I have no problem.(Just be careful when you open it or give warning to your passengers)
#39
I believe Mercedes choice to install hinged doors was simply to distance the car from the minivan image. Their safety reason carries minimal weight; there are two doors on that side and the other is hinged. Also, in certain collisions a hinged door would be more difficult to open. And if the car was submerged, a hinged door is much more difficult to open against the pressure of the water.
The hinged door is one reason against the R-Class in my book. They are too large and are difficult to open in parking places (or in your garage). The only thing against sliding doors is image, of which I care little. Actually, a motorized sliding door is cooler in my mind (and so much more useful) than any other style of opening.
I believe marketing won out over engineering on this one.
#40
#41
+1 for desiring sliding doors.
that said, if R-class was more popular i would NOT have been able to buy a 2.5 yr old $70k car w/ a 5 yrs/100k warranty for $25k.
#42
#43
I seen a guy on here thats got or says hes got an R550, I know Ive never done but that one last week(been doing this since the first year of the R class) but dont know if the other shift has done one or not- its possible.
#44
The biggest concern I have is the wide doors that the kiddos will not be able to handle. But I drive a Q7 and use it on weekends. It takes more attention for the kiddos getting in/out than the Odyssey. Its like being a chauffer.
Has anyone tried the S class doors? It has pneumatic travel limiters that sets the door at the position you leave it, infinitely adjustable, and it has power door latching - you know like the trunk. If you haven't go to your local MB dealer and check it out.We should petition MB to add this to the R!
