oil change
do you guys have an oil guide so I can chose a good weight
steve
How many quarts?
Steve
You MUST use an oil that meets Mercedes specification MB229.5.
This is in your "book." (owners manual)
I have, BTW, never in decades of automotive experience found oil change instructions in an owners manual.
Don't fear, however, Mercedes has you well cared for. Just get the service DVD.
http://www.startekinfo.com/StarTek/o...stedDocId=9124
For all practical purposes, the only motor oil you're going to find that is Mercedes approved is Mobil 1 0W-40 European Formula.
Thanks for the help
steve
https://mbworld.org/forums/r-class-w...tructions.html
My first oil change was $128 from the Stealer (not bad for $30 labor, the rest is cost of oil and oil filter). Service A ($250.00) was due to oil change in one year and my R had only 4000 miles on it. My SA told me to do oil change only.(free tire rotation)
What Mobil 1 weights are good for the r350?
Do I have to use a suction pump or is there a drain plug I can use?
Whats the difference with the euro oil and the us oil?
Thanks for the help
steve
In short - just buy the Service Manual on DVD.
I got 8.5 quarts in.
What range of service does that cover? does it fully explain all the ABCDE----
5W-40 is what they recommend and put in my R320.
I've always let the dealer perform this service & have never been unhappy.
First of all 5W-40 is "thicker" than 0W-40.
But, if you actually check Mobil specs you'll find they both have the same cold pour point and in fact it will be the same for 10W versions, too. These are 21st century synthetic oils and "thickness" is pretty much meaningless.
0W-40 is best for gasoline engines but diesels MUST use the 5W-40/229.51 version and it's ok for gas engines, too. Dealers only have the one in their automatic dispensers.
Any other versions of Mobil 1 are NOT suitable.
