R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
Type A Service Reset
Old Jul 4, 2011 | 09:37 PM
pedra's Avatar
2012 R350 BT - Acura TL SH AWD 2011 - Mustang GT 1994
Looking for the Type A Service reset procedure for a 2006 R500.
Old Jul 5, 2011 | 03:08 PM
lkchris's Avatar
'10 CL550, '12 GL550
http://www.startekinfo.com
look under "workshop resources."
Old Jul 6, 2011 | 07:33 PM
pedra's Avatar
Service Reset
Have the procedure - many thanks.
Old Aug 15, 2011 | 06:50 AM
shobbs666's Avatar
2006 R350
Need Help with Reset this doesn't work
Reset Service Indicator
1. Insert key into ignition, switch to position "1".
2. Press buttons or repeatedly until the mileage is displayed within the Multifunction display.
3. Press cluster illumination button (1) 3 times in short succession. The battery voltage will be displayed
4. Press the up / buttons until the service menu appears.
5. Use the and buttons to select menu option "Confirm".
6. Press button until "Complete Service" is selected.
7. Confirm "Complete Service" with button . The display will show "Service Confirmed".
Feedback welcome on startekinfo.team@mbusa.com.
Any Ideas??
MB
Old Aug 24, 2011 | 10:03 PM
smokersteve's Avatar
06 R360, 06 F350 6.0, 04 CayenneS, 96 911TT 500HP, 86 928S, 74 911S, 73 914-4, 70 914-6, 02 Durrango
Shobbs666, I got to #4, but I move down to confermation using the "+" and "-" but I cant get it to do anything.
Old Aug 25, 2011 | 02:11 PM
shobbs666's Avatar
2006 R350
Smokersteve
Everything is correct EXCEPT # 3. Press cluster illumination button (1) 3 times in short succession. It is NOT the illumination button! Press the R or reset button instead, and I was able to comfirm service and it works.
Old Sep 3, 2011 | 10:57 AM
I turn the key to 1 position.
press R 3 times fast, I then get the battery voltage.
I press the arrows to the service options, and I use the +/- to move down the confirmation. I press R and hold R but nothing happens.
Old Sep 3, 2011 | 11:08 AM
I was able to reset the service. I got to confirmation and held the lower page button, the far left lower button on the steering wheel.
I think I might have done something wrong, I canceled the full service, then I tried it again and I did the proper reset service.
what did canceling full service do?
Old Sep 6, 2011 | 09:40 AM
shobbs666's Avatar
2006 R350
smokersteve
After I comfirmed service that was it. I didn't press the R reset button again. The last step is # 7. Confirm "Complete Service" with button . The display will show "Service Confirmed". After that I just turned the key to the off position. When I started the car the service message was gone. I noticed that the service is set using days nothing to do with mileage at all. It's been 3 months since my last oil change, but I only put on around 1500 miles. You probity only reset the service timer.
Old Sep 6, 2011 | 01:57 PM
So what did that service timer reset that I did do to the system?
