Got the dreaded P0016 and P0017 codes on our 2006 R350...
I've read about the codes (P0016 and P0017) on other classes, but anyone get it on their R350?
What are the chances it's the magnets, sensors or the intermediate shaft?
I'll start with the magnets and then the sensors. Just need to add it to the ball joint repair list...
It has 117K miles.
Are the balance shaft and intermediate shaft the same or different?
How do I determine what code and/or problem I have? I'm not fond of our local dealership. Would my Indy be able to determine this?
I'm not on friendly terms with our one and only dealer in town after our air intake flooded the car during a heavy rain. They and MBUSA were about as helpful as a kick in the nuts.
I'll take it to my indy asap.
Any suggestions from you guys on what do and say to get the best deal from the dealer/MBUSA?
What about current lawsuits on the issue? Where do we stand on those?
Just saw you're response. Tech & Service Mgr. show me TSB for both balance shaft & cam sensor. That was the reason it was replaced @ no charge for labor or parts after 4 days of work/trouble shooting.
don't know what to tell you if you haven't come upon it. I'll look in paperwork, but not sure they gave me copy of TSB.
How hard is it to replace the manifold and why would it need replacing? Does it crack or is it a gasket/vacuum leak issue? It just started to hunt at idle.
I can't imagine the car is worth mote than $15K, so a $9K repair bill makes it difficult to swallow.
Thoughts?
Complaint:Engine light on,Idles rough
and engine reving
Parts list:Intake manifold 1150.00
Balance shaft*** 550.00.
Timing chain**** 395.00
Spark plugs****** 210.00
Intake gaskets*****20.50
Air filters*********88.00
Times 2 oil & filter change 240.00
Cam plugs*******40.00
Engine mounts***375.00
Trans mount***** 95.00
Poly belt******* 110.00
Belt tensioner* **245.00
Idler pulley*******95.00
Total*********3613.50
Tax********** 252.95
Parts total***** 3866.45
Labor******** 5200.00
Grand total**** 9066.45
Same run around deal when the air intake drain clogged and water damaged the blower motor. I fixed that in an hour and a $150 part.
Can MBUSA suck any more?
Left it there and a bunch of wrenches looking at it when we left.
Thanks Mercedes Benz....
