shaking car with big wheels (22")
R-320 CDI 4Matic
hey, some time ago ive mounted 22" on my R320cdi
but they where shaking from about 60mph and upwards...
went to a new shop to get them balanced again... still shaking... off to new shop new balancing... STILL SHAKING!!!!
one of my freinds also have an R320 with 22" and his is also shaking...
if we mount our 17" winter wheels nothing is wrong... our 22" is 100% balanced...
any clue???
any clue???
R-320 CDI 4Matic
I would check the steering ball joints and suspension bushings. I'm assuming the new wheel / tire combination is heavier and has a different offset than original spec. This might result in an oscillation or shimmy from worn suspension that didn't happen with the stock wheels.
Have you had the suspension and components looked at?
Like Pete mentioned large/wider wheels will show you your suspensions weakness.
Also, you said you had your wheels balanced over and over again...
Did you have the techs check if the tires were well balanced before you had them balance them again? Or did they just start from scratch assuming that the tires weren't balanced?
2011 C300 4matic, 2015 Porsche Macan S, 2006 R500 (sold)
any clue???
any clue???
