R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
MP3 Player 2007 500 R
Old Nov 9, 2017 | 04:10 PM
amussari's Avatar
2007 500 R
Is there a way to hook up an MP3 player via an Aux? My model a 2007 has the center entertainment area, so there is no Aux jack in the glove compartment. Is there some place else I should be looking
thanks
Anthony
Old Nov 11, 2017 | 05:01 AM
efzauner's Avatar
2005 C240 2011 R350
you mean you have the rear entertainment system? If so, correct you dont have an aux jack. But you do have auxiliarry R+L +Video inputs on the DVD Player in the armrest. You can connect that way.
Old Nov 11, 2017 | 11:48 AM
amussari's Avatar
2007 500 R
I don't believe the sound from the MP3 player can be heard in the car with that type of hook up other than the passengers with headphones.
Anthony
Old Nov 11, 2017 | 02:02 PM
efzauner's Avatar
2005 C240 2011 R350
Originally Posted by amussari
Anthony
Did you try it???? you have to turn one of the rear displays on, and select aux 1 or aux 2. I set in on the passenger display so I could easily reach back and turn it on from the drivers seat.
Old Nov 11, 2017 | 03:40 PM
amussari's Avatar
2007 500 R
efzauner
I'll give it a shot and let you know
Certainly worth a try
thanks
Anthony
Old Nov 12, 2017 | 09:27 AM
efzauner's Avatar
2005 C240 2011 R350
efzauner
thanks
Anthony
You do have the remote control for the displays? you will need it.
Old Nov 16, 2017 | 02:38 PM
amussari's Avatar
2007 500 R
OK
I got it to work
thanks
next getting the cigarette lighter socket and the rear power socket to go on. I did change the fuse(s) but nothing.
The center power socket does work, thankfully
Anthony
Old Nov 17, 2017 | 07:54 PM
efzauner's Avatar
2005 C240 2011 R350
OK
I got it to work
thanks
Anthony
That is odd... did you check the fuses again? they are easy to blow with a short adaptor that allows the ground to short to a positive connection on the side of socket...
Old Nov 17, 2017 | 07:55 PM
efzauner's Avatar
2005 C240 2011 R350
OK
I got it to work
thanks
Anthony
you are welcome!
Old Dec 27, 2023 | 12:52 PM
dionisg's Avatar
w221 S320L 2007
Anthony
what type of cable required? I have an Iphone 13 (hope it will work)
