ESP unavailable see owners manual
I took the car for a wheel alignment and yesterday (two days after and about 50km made) ESP UNAVAILABLE SEE OWNERS MANUAL message came along with the yellow triangle and TYRE PRESSURE CONTROL NOT WORKING (or something like that, translated from Spanish).
I will go back to realign the front wheels holding the steering wheel 10 degrees to the right as it was before the alignment and the fault messages, and see if the messages go away. Could the problem be caused by misplaced steering wheel by the guy who fixed the key problem and took out the steering wheel? If so, wasn’t the steering angle sensor supposed to trigger the ESP message? Do some of you recommend something else? Thank you!
Anyway, after the whole thing is done, I will write here what I will know.
I once hit small bale of pine needles which fell from a truck on the highway. This was in a Toyota Prius.
It went under the passenger's side wheel and tore out the fender liner under there along with some damage to the front bumper.
Other than that everything seemed good. A few weeks later I took it in for an alignment after getting new tires and when I got it back the steering wheel was off by about 10 degrees.
The mechanic showed me how the wheels were NOW aligned properly according to the laser guided machine.
Apparently the impact bent something which now makes the steering wheel off.
His suggestion, since he didn't see anything obviously wrong when he was under there doing the alignment, was to take the steering wheel off and make adjust it to dead center.
Taking vehicle to the MB shop maybe your best bet since the pros who align suspensions didn't not anything wrong to you.
Plus you have a lot of electronics misbehaving and that's the realm of the dealer or a good independent.
I'd go to the independent before I go to the dealer bcos the indy will like to fix just the issue. The dealer would like to replace the whole steering column and module. That might be a bit of an exaggeration... but not by much.
Good luck and keep us posted!
I will confirm everything once I have the car fixed.
for now I am satisfied.
