What's this oil leak?
Jirong
Common leak point for the OM642 diesel is the oil cooler located in the vee (valley) of the engine block.
At this moment the leak is not so bad so I can wait. This week I notice the turbo to air intake was leaking a bit after I replaced the fuel filter last month. I've replaced the seals yesterday to eliminate the leak from the top.
The oil cooler service won't be free, but will be thousands of dollars less than if you got it done separately.
See my comment here:
https://mbworld.org/forums/r-class-w...ml#post8605399
