R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
Will 265/60/R18 Tires (on 18x9 Rims) fit an R500
Old Dec 2, 2022 | 05:13 PM
speedwheels's Avatar
R500
Apologies for the dup post (i couldn't change the subject line).Folks, I am trying to figure out if 265/60/R18 tires on 18x9 wheels (ET56) will fit on my 2006 R500.
My 2006 R500 has 18x8 Rims with a 67 Offset and 255/55/R18 tires (total diameter of 29 inches).
The new wheels are +56 So the wheels are going to stick out more but may be ok. However the tires are 265/60/R18 which have a diameter of 30.5 inches (stock is 29 inches). Will the tires rub in the fender due to the additional 1.5 inches in diameter? Anyone know how tall of a tire the R500 can accept? I like the idea of going with extra sidewall for a softer ride.
Old Dec 2, 2022 | 08:40 PM
slawek's Avatar
I run 21 x10 offset 56mm with 275/40 -21 pirelli scorpion verde
Old Dec 2, 2022 | 08:49 PM
R500
That is a good reference. Thank you . That would make it 29.7 Diameter. Hmm. I will be going a bit bigger than that..
Old Dec 2, 2022 | 09:31 PM
slawek's Avatar
275 -40 is the max size in 21" I did not wanted to do tires in 285/35 or 295/ 30
Old Dec 3, 2022 | 12:54 PM
Tsumi's Avatar
2006 R500
I traded rims with a GL owner (19" rims, stock wheel size for GLs). As I recall, there was a bit of rubbing on the liner at full turn. I didn't keep this configuration long as the wheels needed to be replaced.
Also, keep in mind the spare tire is sized for the stock R tire size. Going to GL sized wheels means that your spare will be significantly smaller.
Old Dec 3, 2022 | 12:56 PM
R500
Do you recall which year GL it was? And any chance remembering the tire size? Thanks
Old Dec 3, 2022 | 12:59 PM
Tsumi's Avatar
2006 R500
2009 or 2010 GL450 I think.
Old Dec 3, 2022 | 01:07 PM
R500
Great Info. That would be a 275/55/R19 which would make it a 30.9 inch tall tire with an offset of +56.. I guess getting a 30.5 tall tire on an 18 inch rim with the same offset would be asking for trouble.. Oh well..
Old Dec 7, 2022 | 02:34 AM
mustnged's Avatar
2006 R500, 2017 GLE43
I also have 2013-2016 19x8.5 GL Rims with 275 55 19 tires and am experiencing slight rubbing front left tire only when turning right. On my 2006 R500. May swap to different rims soon.
Old Feb 21, 2023 | 10:43 AM
Minibenz's Avatar
13 E350 coupe, 06 R500, 10 E350, 99 C43AMG, 95 E320, 83 300D turbodiesel, 83 380SL
Tire Rack may be helpful for anyone interested in making changes. Go to their guide and you simply give your details to see if it will work
https://www.tirerack.com/content/tir...n/wheels.htmld
