R63 AMG (W251) 2007 - 2013 Discuss the R63 AMG.
Rclass specific Wireless Apple CarPlay/Android Auto
Old Jul 14, 2020 | 09:35 PM
rbtmak's Avatar
GLS63, R63, Cayenne Turbo & GTC4 Lusso
Works perfectly. Integrates with the steering wheel controls and Harman Kardon system with no issues as kit includes MOST and Canbus decoder. Two hours to install. Made specifically for Rclass and really modernizes the infotainment.
Without the Comand, you need to go to a Mercedes dealer and have them program the ability to change your clock from the steering wheel - they charged me an hour to do the coding. Otherwise, you will not be able to adjust your clock. This is the only feature you lose from replacing the Comand unit but easy to address.
Purchased on AliExpress. USD$400.
Digital Sound processing to better use the factory amplifier. Great sound!
Old Jul 15, 2020 | 05:36 PM
1955W196S's Avatar
R 63 AMG, Mercedes E320
Looks great! Do you have a direct link? Does it include a CD/DVD slot? Can you (or a future owner) reinstall Comand to take it back to original if desired?
Old Jul 15, 2020 | 06:15 PM
rbtmak's Avatar
No CD/DVD slot but can be easily removed to reinstall original Comand unit. 100% reversible
https://m.aliexpress.com/item/400081...1102e01&is_c=Y
Old Jul 18, 2020 | 06:02 PM
marivip's Avatar
R500
Hello
Am i good to understand that you ordered this stuff and you didn't have any problem with fiber cabel (Harman Kardon amplifier) and with CanBus?
Everything was included?
I'm looking for radio like this but lot of company offer radio and then extra option like fiber decoder and can-bus decoder?
Old Jul 18, 2020 | 08:10 PM
rbtmak's Avatar
Hi, please see attached pic. The unit comes with Canbus decoder so you only need to add the Most unit available from the same seller. Then it’s plug and play. It’s fully reversible.
Old Jul 21, 2020 | 05:00 AM
marivip's Avatar
R500
Thank you!
Old Sep 24, 2020 | 04:56 AM
marivip's Avatar
R500
@rbtmak i have an technical issue.
How you connected your radio to most?
My "most" have only 2 chinch (chanel left and right) and radio have 5 separately chinch (FL, FR, RR, RL, Sub)
I connected "most" to FL and FR but when i steering amplifier it play only front (natural) and i didn't hear woofer in car.
I thinking about cross right sides, and left sides to one chinch but what with woofer again cross to one channel? But i think that "most" can burn - to many voltage (signal) or can burn radio...
By the way, my radio works with clock in dashboard, i can set from radio time which i see on dashboard
Thank you in advance from answer
Old Sep 24, 2020 | 11:12 AM
rbtmak's Avatar
Hi, I am sorry, I am not sure as I had an Audio Shop do the install for me. But I do have this and hope it helps......
Old Jan 11, 2021 | 12:02 AM
Pseudo Nim's Avatar
Curious if anyone bought this. Does this connect into the fiber optic network? Some of the navis seem to go directly into optical ...
Old Mar 1, 2021 | 08:07 PM
glockster's Avatar
1991 MB 300TE-24, 1996 BMW 318is, 1998 BMW M3, 2007 MB R63, 2008 Renault Kangoo
Hmm, very very interested. However I wonder if this unit works with my 63, mine has side view camera built-in.
Old Mar 1, 2021 | 08:22 PM
Pseudo Nim's Avatar
Side view OEM or aftermarket? I didn’t realise MB had any side view equipped cars in 2007.
Old Mar 1, 2021 | 08:28 PM
glockster's Avatar
Side view MB factory.
Notice the button layout is different also. I tried to change logo when startup so that it shows AMG instead of MB-star, but I got no factory settings menu by pressing 3-button at the same time for some seconds.
I guess our version gets something different from the rest of the world.
Old Mar 1, 2021 | 09:01 PM
Pseudo Nim's Avatar
Damn wow that’s unique.
I’d say you’ll most definitely would lose that if you went with an Android solution. Potentially the dash mounted one I linked might work - but I haven’t seen if that one wires into the optical network (and I don’t think it does, because if I’m not mistaken, you don’t add devices to an optical network - you replace them). Therefore you’d probably need to hook it up via stereo, which kinda sucks.
Old Mar 1, 2021 | 10:03 PM
glockster's Avatar
Yeah. That is the only thing keeping me away from updating the unit to the 2020s spec.
Old Mar 2, 2021 | 12:15 AM
rbtmak's Avatar
This aftermarket deck was not compatible with the factory rear camera, but it came with a new camera to replace in the same spot.
I imagine you would lose your side cameras if you changed out the head unit.
