S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Blue Smoke Going Down Hill 300SEC
Old Oct 9, 2007 | 10:38 PM
pkbell's Avatar
I have a 1981 300sec with 159,000 miles on it. It now blows out blue smoke after letting off the gas going downhill and giving it gas at the bottom. I get a big puff of smoke then it stops. I get no smoke as I accelerate. Or travel at a fixed speed. I just had new valve seals put in because I was having little puffs smoked coming and a little oil consumption. After new valve seals I get more smoke and oil usage the ever. Can vale seals be put in wrong or what? Bad ring, Bad valves or valves guides ? What to do next?
Thanks PKBell
Old Oct 10, 2007 | 05:10 AM
nomad's Avatar
280SE W116, 500SEL W126
I'm betting it's the piston-rings
Old Oct 10, 2007 | 01:17 PM
Untertürkheim's Avatar
What kind of oil do you use?
Old Oct 12, 2007 | 01:54 PM
evita's Avatar
Hi
I had same problem
I have a 1991 560 SEL , exactly as same as yr situation.changed the seals and problem was still there
I am not a technical person, but mechanic showed me the "TYPPETS" which seals are put around them ?? and they were very slightly bended.
Changed them ,got it brand new from germany and now the engine is same as new.dont loose oil at all.
Sorry for my technical ignorance
Old Oct 15, 2007 | 02:47 AM
luda's Avatar
ML 320, 1998
I would guess that the valve guides are worned out. New seals can not compensate for badly worned guides.
P.E.
Old Oct 15, 2007 | 12:37 PM
BENZITCH's Avatar
1991 560SEC Teal 1989 420SEL Ice Blue 1984 500SEC White
It could be one of the seals were knicked when installed.
Old Jun 30, 2008 | 04:08 AM
I am having nearly the same problem in my 1988 560SEC. The car runs extremely well except for an intermittent problem when going down a long steep hill and coming to a stop. After accelerating from the stop, the car hesitates and seems as if it might stall, but it produces a huge cloud of smoke (as in zero visibility behind the car, stopping traffic) as it burns off the oil getting sucked in.
The car is completely upto date on all service and has been gone over carefully. The timing chains are nearly new, and I was told the valve seals are in good condition. 125k miles on the engine.
Has anyone solved this problem? I know there is another thread from a French member who has this problem with his 500SEC.
Old Jun 30, 2008 | 02:56 PM
The shop foreman at the MB dealer thinks that this problem is simply the transmission modulator, which makes the most sense to me based on the symptoms and the color/scent of the smoke. I will post updates.
Old Jul 1, 2008 | 10:27 AM
BENZITCH's Avatar
I would look at the modulator prior to the valve seals, since the labor is much less on the modulator, and the smoke can eb similar in color.
Have you had a leak down or compression test done to ensure valve/ring condition?
