380 and 420 SE/SEL owners come on in!!!!!!
Either one will get about 20 on the highway if in top-tune, possibly 22 with the 380 with all the right coaxing.
There are several 420's for sale up in this area ana I think a couple of 380's too...
I may go for a 420 just because they are a bit newer.. I'll have to see how nice they are.
If buying 89 is the start of the last changes for the w126 series.
Look for dual air bags though.
https://mbworld.org/forums/mercedes-vehicles/265888-fs-w126-mb-380se-s-class-only-66k-miles-nj.html
I assumed you wanted an SE because of the 300SE you were looking at, and I would reccomend one unless you normally have very tall people in the back.
I thought the 380's had issues with the timing chain? I figured when they upgraded and updated to the 420, they probably solved most of those type of issues..
I'd rather have the 6 for gas mileage, even though the 8 is close to the same. I know me, and my foot would be in the 8 more often.
I have driven all iterations of the 126, and for the driver the SE is much better than the SEL (which is why nearly all 126 in Europe are SE). Those extra 6 inches make the car much less nimble, and it is only for the rear passengers, the car are identical except for the rear doors.
The 300 will be the most efficient not only because of the displacement, but it is a much newer engine design, the M116/117 was developed in the 60s while the 103 was a mid 80s design. Also, the 300 makes nearly the same HP as a 420.
I have already contacted a couple of local guys that have SD parts in search of a 81-84 differential, per your suggestion as well.
Thanks..
That engine is really a good one, people think that the car is underpowered but it is simply a matter of a differently shaped torque/power curve. Of course, the 3.46 differential was made to compensate for that, but the gearing was too low for me, 85mph is about 4k rpm, and hearing the engine so loudly while cruising on the highway was just annoying and wasting gas. The 3.07 should bring it down to about 3500, which from my experience driving that car, would be ideal. Not to mention, in Europe the 300SE was offered with th 5 speed manual were the top gear was 0.82:1, making top gear drive 2.82:1 with the 3.46
From what you have said, that 300SE does sound like a very nice car! Post some pictures if you can of whatever car you end up in.
