S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
fuel leak
Old Oct 16, 2010 | 04:51 PM
littlebuddy's Avatar
84 300sd
fuel leak
I have a 84 300sd.After changing the fuel filters the spin type developed a fuel leak at the top bolt.I tighten down the bolt and still leaking. I do not see a copper washer under the bolt,and I don't see on listed on the parts illistration.How tight should that bolt be ? Normally,filters are hand tighten only.Kevin
Old Oct 17, 2010 | 09:24 AM
MBtech1098's Avatar
10 speed bicycle
Did you replaced the two o-rings on the bolt?
Old Oct 17, 2010 | 10:22 AM
84 300sd
fuel leak
Are the O rings rubber, and go on the shaft of the bolt?
Old Oct 17, 2010 | 10:44 AM
MBtech1098's Avatar
10 speed bicycle
Yes...there should be two of them.
Old Oct 17, 2010 | 10:50 AM
84 300sd
fuel leak
Ok I'll pick them up. The fuel filter came with 3 copper washers ,no rubber o rings. Should the filter be hand tight like normal or tighten it down with the hex head bolt?
Old Oct 17, 2010 | 10:54 AM
MBtech1098's Avatar
10 speed bicycle
Tighten it with the bolt...but don't crank on it.
Old Oct 17, 2010 | 10:56 AM
84 300sd
thanks
Old Oct 17, 2010 | 01:51 PM
84 300sd
fuel leak
After replacing the O Rings the leak stopped. thanks
