S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
High speed fan setting for HVAC not working 1990 300SE
Old Nov 11, 2004 | 01:43 PM
cam69ss's Avatar
1990 300SE
Hello All,
I have a 1990 300SE with 236,000 miles and the high speed fan for AC and heater does not work.
I took apart the HVAC controller and re-soldered all the joints. Still not working. Any ideas of what the problem could be?
Thanks in advance
Dan
Old Nov 11, 2004 | 03:22 PM
Jer's Avatar
Jer
1994 E320
Check the blower motor regulator, located in the fresh air stream of the heater box.
Old Nov 11, 2004 | 04:35 PM
cam69ss's Avatar
1990 300SE
Jer, Thanks for the reply
what is the blower motor regulator? Is it electrical or mechanical? Similar to a relay?
Anyone know how to get to it on a 126 car?
Old Nov 11, 2004 | 04:50 PM
Jer's Avatar
Jer
1994 E320
It is a transistorised controller for fan speed regulation. You get to it through the fresh air grille under the windshield (at least on a 124).
Old Nov 11, 2004 | 05:27 PM
cam69ss's Avatar
1990 300SE
So I have to take out the dash pad?
Old Nov 11, 2004 | 05:29 PM
Jer's Avatar
Jer
1994 E320
No. The fresh air grille is outside, near the wiper transmission.
Old Nov 11, 2004 | 05:31 PM
cam69ss's Avatar
1990 300SE
right in front of the wiper trans. area, in the engine compartment?
Old Nov 11, 2004 | 05:48 PM
Jer's Avatar
Jer
1994 E320
Not in the engine compartment. Under the windshield. You can't miss it.
