Reliability of 85+ 300SD
Ignition coils? Where did you read about that? That's not a common problem on the W126s. Especially with the kind of mileage on that car your friend is interested in -- if the miles are true and actual.
I have an '85 300SD with about 200k miles on it and the engine is in great shape. But nearly all of the systems that Braverichard mentioned need attention. The previous owner of my car did not fix many problems as they arose. My AC, climate control vacuum system, vacuum operated door locks, etc. all need troubleshooting. Maintenance by the previous owner is the key. If he changed the oil and filters religiously and fixed problems as they arose, then mileage is not an important factor because many of the parts that periodically wear out will have been replaced anyway.
From what I have read, 150k is about borderline for potential future transmission work. That would be a possible large future expense.
My impression so far, after a couple of months with my car, is that it will be an economical, long-term vehicle (barring catastrophic failures) for a shade tree mechanic. If you pay someone to do your car maintenance for you, it may be harder to justify from an economic standpoint.
RayG
I was wondering the same thing. Ignition coils??
Even on the MB gassers they aren't a common issue.The key to owning one of these old but reliable cars economically is knowing well about them. I've been too busy or lazy to perform certain repairs/maintenance on mine many times and have had to pay someone to perform them, but still without going bankrupt. The key is knowing well enough about the car that when something happens, you're confident enough to order your own parts and go to a trusted mechanic and say "this is what I want you to do... nothing more, nothing less" and be 99.99% correct. That's my case. Most of the work that I don't do is done exactly as I say and I've never been wrong so far. You have to know the car very well or else you can be talked into changing parts that are perfectly fine. I've been told silly things like that the timing chain must be changed every 100K miles along with the water pump when I know a 300SD with its original chain at 322K miles! I've also been told that the injectors need to be changed every 100K miles, that the shocks need frequent changes, etc. If I didn't know enough about the car I could have been cheated. Also, these cars are so simple to work on that you can convince your MB-scared backyard mechanic to work on it for you without much effort.
1. A good mechanic that knows them and can keep it running.
2. Not being afraid of paying that mechanic $3k-$5k a year to keep said W126 going.
Sorry these are old cars you really should be a diy'er or know something about these cars at least. If not ownership just is not pratical. Try a newer W210 or another newer car insted.
But according to the ebay sellers these cars all go 500k miles will little maintaince so I may just skip the oil change because I wouldn't want it not to make 500k!
I'm not trying to be hard on the guy just trying to help him avoid getting burnt on an old car.
