S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Factory Phone question
Old Apr 23, 2005 | 06:42 AM
Mr. Benzito's Avatar
1992 300SE (w140) / 1997 E420 (w210)
Hey all,
Quick question about the factory phone and dialing pad that's located in our vehicle. I am installing an aftermarket system in my car in the next two weeks, and the installer said that I would lose functionality of the phone (which I don't really care since I don't use it), but I wanted to know what the clearance was behind the dailing pad in the dash? Have a couple of ideas, but it involves that space. I couldn't image that it is too deep, but if anyone has removed it, or furthermore knows what is behind it would help.
Thanks!
Old Apr 23, 2005 | 12:25 PM
BenzKid24's Avatar
a Few Nice cars.
its just a hair past 9'' wide and 4''deep,hope that helps
Old Apr 23, 2005 | 04:11 PM
does anyone know how to remove the keypad. I rather do it myself then take it to my mechanic. What's actually behind it though? vents?
Old Apr 24, 2005 | 03:54 PM
BenzKid24's Avatar
a Few Nice cars.
nothing just storage area,ui have a s500 with the phone keypad,but i havnt tried to take it out
Old Apr 26, 2005 | 08:10 PM
brett san diego's Avatar
1997 S600 Sedan
It just slides in and clicks in place. Along the top edge of the unit are two notches. Insert flathead screwdrivers or something similar to press the tabs down and pull the phone unit out. Very easy to do.
Brett
Old Apr 27, 2005 | 05:25 PM
mrbilldata's Avatar
I had my phone pad removed at a dealer and they put in an insert that is only as deep as a US dollar (less than 3"). I assume MB would have made it deeper if there was more space.
Old Apr 27, 2005 | 07:08 PM
I was actually going to ask about that. I heard that some people don't have the factory phone (which I thought was a standard feature) and actually have a storage compartment like what your describing.
I was actually thinking about putting a small equalizer in that location, and with a 3" clearance that might actually be enough space. Now the only thing to figure out is the wiring for it ...
Old Apr 28, 2005 | 10:51 AM
mrbilldata's Avatar
Just to clarify something I may have misrepresented.
The depth along the bottom is about 3 inches. But
the depth along the top is only about 1 inch. You
would have to tilt the EQ down against the air vent.
Bill
1995 S320 with a new crate engine Feb 2004... with
the infamous blown head gasket Jan 2005... :-(
Old Apr 28, 2005 | 10:53 AM
Peter Guenther's Avatar
92 500sel/01 320e wag
To remove the control, release the two catches at the top and slide forward (disconnect the cables). The bracket is bolted to the top of the bin thru the bin, you might get the screws out but you will lose the nuts behind the dash. You will not gain any more space since the bin is held by two screws in the back. You can also gain space by removing the handset and cup in the console, remove the bottom and brush up the nap. There will be no loss of radio functions since the phone only muted it and the cell audio was routed to the outboard speakers on the dash! In 92 it worked that way
Old Apr 30, 2005 | 07:07 AM
I was even wondering if it were possible to fit a center channel speaker in that location. Before anyone says anything, I know there already is one in the vehicle, but bare with me. What do you guys think about the following:
Now, I am keeping in mind that it would have to be tilted still, and even wondering if I could fit it deep enough such that I could still close the privacy flap covering the keypad if I were to place the speaker. I am trying to find a place where I live that actually sells the speaker so that I can get the dimensions, but let me know what you think.
