S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
'96 S320 door noise
Old Apr 28, 2005 | 10:26 AM
Rod Spohn's Avatar
2011 E350 Bluetec, 1996 S320 & 2006 E320 CDI Sold to my son & 2017 GMC 2500 Diesel Pick up
'96 S320 door noise
I have a '96 S320, when the drivers door is opened it makes a snapping or clicking type noise. Looking at a parts diagram it looks like there is some sort of Plate or something in the door panal that may have something to do with it. My quess just worn out catch or something. Before digging into it do you think this is the problem or is it something else? Thanks
Old Apr 28, 2005 | 07:31 PM
dlafever's Avatar
'15 S550, '10 E350 P1/P2, '02 ML320
Rod,
This sounds like the door check strap to me, about $34 at buymbparts.com. This will require door panel removal but is otherwise quite easy.
Old May 4, 2005 | 06:24 PM
Rod Spohn's Avatar
Thanks Again
D _ Thanks thats the part I saw in a catalog. You are as usual a great help
Old May 24, 2005 | 02:40 AM
Bernanke's Avatar
hey guys, i think i may have this same problem. does your door also make noise while driving? I'm getting a lot of rattle from my passenger side door as im driving down the road, like metal on metal contact. and my drivers side door makes a rattle when i close it as well. thanks in advance for your help.
Old May 25, 2005 | 10:35 AM
Rod Spohn's Avatar
OmeyHomey
OmeyHomey , On mine someone told me to try tightening the two bolts that attach the Door check strap. I thightened them and the noise went away. Give it a try I was glad I did.
Old May 25, 2005 | 07:05 PM
Bernanke's Avatar
excellent, do i just have to take the door panel off or what? any basic instructions? thanks again
Old May 26, 2005 | 08:54 AM
Rod Spohn's Avatar
OmeyHomey
OmeyHomey, check out the photo above in post. See the two nuts welded on the mid point of the door strap? the two bolt that are on the door where the strap goes into door are the ones you tighten. No removal of the door panel is needed, unless you end up needing to replace the door strap. Good luck.
Old May 27, 2005 | 06:14 PM
brett san diego's Avatar
1997 S600 Sedan
Here's the fix for clicking door checks
I did this last fall, however, the door is starting to click again quietly as I expected.
http://www.mbnz.org/forums/forums/th...ng+door+checks
Brett
