S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
drill brembo rotors
Old Oct 10, 2005 | 12:20 PM
rambo006jr's Avatar
drill brembo rotors
anyone have any experience with these rotors? are they anything good? attached is a link to an ebay auction on them. i heard from the mechanic that I need matching brake pads to work with them. any feedback is greatly appreciated.
http://cgi.ebay.com/ebaymotors/Drill...spagenameZWDVW
Old Oct 10, 2005 | 01:13 PM
maci911's Avatar
02 s430,98 S320,05 ESV,02 Caravan
i bought exactly same from same seller i think these are the cheapest on ebay i had them for about a year ....no prblem so far ... i bought brake pads from another seller ebay the front pads fit but the rear didnt ...idont know why ... the shop had to buy the rear somewere else.... u definetly want to look into it....
Old Oct 13, 2005 | 09:06 PM
rambo006jr's Avatar
do you think the braking performance is noticibly better? how much did the pads cost and do you know what size pads I need? Thanks.
Old Oct 14, 2005 | 12:06 AM
Bernanke's Avatar
i have heard very bad things about cross drilled rotors (especially the brembo ones). They are truly drilled instead of CAST which means there are microscopic stress cracks which can ultimately lead to a cracked rotor (VERY BAD). so be careful. just getting better brake pads would probably yeild better braking.
Old Oct 14, 2005 | 12:25 AM
E55AMG99's Avatar
1951 Caterpiller D6
How do you think they make them? HINT: The name gives it away!
Cheap cross drilled rotors do not have chamfered or radiused (better) holes that limit or eliminate stress cracking.
Old Oct 14, 2005 | 12:47 AM
Bernanke's Avatar
NO THAT IS NOT WHAT IM SAYING, you dont know what u are talking about....
TRUE BREMBO cross drilled rotors are not DRILLED at all. they are CAST that way in one solid cast. anyone who knows anything about brakes knows that. Those on ebay are just brembo blanks drilled thats why they are dangerous. All OEM X-drilled rotors are CAST, those found on porsches, ferraris and benz and etc are all CAST cross drilled to ensure there are no stress cracks and etc. If you dont konw what u are saying don't comment.
Old Oct 14, 2005 | 01:21 AM
E55AMG99's Avatar
1951 Caterpiller D6
Put down the crack pipe and calm down man.
First off, I know plenty about brakes. This is an old topic that has been beat to death many times in many forums . The holes in almost all Brembo aftermarket rotors are cross drilled, not cast in. Yes, most high dollar OEM applications that use Brembo have the holes cast into them before machining but not all OEMs use cast holes. The cost to cast them in before machining is huge and because of this almost no aftermarket rotors are cast this way. Anyone who knows anything about brakes knows that.
Old Oct 14, 2005 | 01:31 AM
E55AMG99's Avatar
1951 Caterpiller D6
...and BTW, try reading what Brembo has to say on the subject.
Their site is not very friendly but here is a link to their FAQ on another site.
Personally, I think the answer they provide applies only to rotors drilled by Brembo or to their specs and not by someone else using poor techniques.
Old Oct 14, 2005 | 09:22 AM
maci911's Avatar
the pads cost me like 60.00
Old Oct 14, 2005 | 03:44 PM
brett san diego's Avatar
1997 S600 Sedan
Regardless, cracking of OEM Porsche cross-drilled rotors is a normal occurrence. Porsche owners recommend replacing the cracked rotors when the cracks near the edge of the rotor.
Brett
