S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
transmission problem !! HELP ME !!!!
Old Dec 18, 2007 | 09:57 PM
purrfect's Avatar
S320 1997
Unhappy transmission problem !! HELP ME !!!!
hi all
i own an S320 1997,
about a week ago i started notecing that the gears are being shifted with a "kick" and then it got worse,
it would just miss the gear shift and i would have to let go of the gas pedal for like 3 sec's for the car to switch gears, and now i noticed that the car is "stuck" on the 1st gear (this is after 1 week)
can anyone tell me what can this be and what can i excpect in terms of costs for this ?
do i need a new transmission ? <- and if so what are ongoing rates to get those ?
Please Advise!
also,
i'm located in toronto canada
any ideas who is a good mechanic in the city for benz's ?
any advice will be greatly appreciated !
Old Dec 19, 2007 | 12:32 AM
NZ_Benz's Avatar
1993 300SEL/S320
Hmm I think you might be in for a rebuild sounds like it was low on fluid and ate itself, first thing would be to have the fluid and filter changed and take it from there see if that improves things.
Old Dec 19, 2007 | 07:44 AM
purrfect's Avatar
S320 1997
i'm taking it to aamco scarborough today to have it checked
they offer a free twoing service and something called a transcan to identify the problem,
i hope it stays below 1k, this time of the year i hardly would call this "buying a present" money...
will post back shotly with results
thanks.
Old Dec 19, 2007 | 11:13 AM
BENZBAEZ's Avatar
Anything I can afford
Probably just the solenoids in the valve body. The electronic board goes bad. Clutches hardly ware out on this trany but the internal seals start to leak causing some slipping and erratic problems.
Old Dec 19, 2007 | 02:06 PM
purrfect's Avatar
S320 1997
just got out of aamco scarborough
they couldent find any computer errors after scanning it with the scanner and they told me that the oil inside is bad
also told me that there are no chuncks of metal meanning there are probobly no broken parts in it
they quoted me just under $1900 to take the transmission apart, inspect it, replace ONLY THE SOFT PARTS as they call it, and i got them to agree to give me a rental for 2 days until they finish the job in 2 days
they promissed lifetime warrenty with it
i feel like this is allot for this kind of a job
the extras they included was
free towing of my car to their shop
and free rental car for 2 days (or $60)
thanks
Old Dec 19, 2007 | 07:36 PM
NZ_Benz's Avatar
1993 300SEL/S320
thanks
That sounds ok if they have to un-mount the box from the car and replace all the parts and re-fill and refilter.
Old Dec 20, 2007 | 11:12 PM
purrfect's Avatar
S320 1997
Thumbs down aamco blows
actually things took an ugly turn
i called them today to verify everything was fine and the guy told me that i need some hard parts as well
the parts were
sprag asemly
k2 forward drum
and 3 more parts which i dont remember the names for ( ill post next time i have a chance)
and quoted me $3600 for the job, what a rip off
what happens if i dont want to proceed the guy said i'd still have to pay the original $1000 for the labor of taking it out > dissassemble > reassemble > put back + some of the "soft parts"
which will come out to $1500 + taxes
RIP OFF !!!!
i asked him to stop the job and asked what would be the cost of leaving everything as is and for me to tow the car away he said he cant do that since he took it apart and that he "has" to put it together and charge me for the entire thing $1500
also he said that if i want to put it together he wont be able to have it done by tomorrow and that i will have to keep the car there until after next week
which creates a hugh expense for me with the car rental (at least $500)
i am frustrated as all hell about this and seriously considering about going to the media with this
also, when i said, what if i pay you the $1500 and you keep everythig as is condition, just put the tranny in a box and ill tow the car away
suddenly he said "ill check into that" and came back with , yes we can do it
so its obvious aamco is a complete rip off and they are out to lure you in with "free towing" and 1 day car rental's and meanwhile they are sticking it to you in fees and labor charges.
any suggestions anyone ?
Old Dec 21, 2007 | 08:09 AM
Rod Spohn's Avatar
2011 E350 Bluetec, 1996 S320 & 2006 E320 CDI Sold to my son & 2017 GMC 2500 Diesel Pick up
"so its obvious aamco is a complete rip off and they are out to lure you in with "free towing" and 1 day car rental's and meanwhile they are sticking it to you in fees and labor charges.
any suggestions anyone ?"
Learned that lesson myself several years back with them. Sorry to hear they are the same every where. Do you have a better business to report them to up there? Use it & get the word out that about all you can do unless you take it someplace else and they don't find the same issues and fix it without the hard parts. Then you have some ammo
Old Dec 25, 2007 | 02:29 PM
jhodg5kc's Avatar
ON SUSPENSION
Quite a few:)
Well, first thing..NEVER take a Mercedes to Aamco...you need to bring it to someone who specializes in Mercedes transmissions. To properly rebuild your trans w/ fresh clutches/bands, torque converter will usually run about 2-2500 for a shop that's doing the job Right. Add is worn out/broken internals and the price can go up quickly.
You can always bring it someplace else for a 2nd opinion. Perhaps you can find someone that has a good core they can rebuild as to cut down on your rental/turn around time.
Jonathan
