S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
accumulators
Old Jun 5, 2008 | 10:13 PM
OdinsThrone's Avatar
1998 S500
Thumbs down accumulators
How do you know if your accumulators are no good? Mushy ride or harsh ride indicate faulty accumulators? I replaced my accumulators about a little over a year ago because a mechaninc told me they were shot because of how the back end was bouncy. I replaced them with new ones ,and now it feels like there is 200 lbs of air in my tires when I go over a small bump. Feels like the car is rigid ,and does not absorb any flaw in the road at all.
Old Jun 6, 2008 | 12:23 AM
NZ_Benz's Avatar
1993 300SEL/S320
Have a read of this:
http://v12uberalles.com/Accumulators.htm
Perhaps it's leaking fluid somehow?
Old Jun 6, 2008 | 09:19 PM
1998 S500
No leaks in shocks or anywhere else? Thanks for the reply.
Old Jun 7, 2008 | 03:40 AM
NZ_Benz's Avatar
1993 300SEL/S320
Are you sure did you check the fluid level under the hood? You might just not be able to see it.
Old Jun 12, 2008 | 01:55 AM
1998 S500
Cool
The resivor is full I disconected the linkage in the back put the arm to lower car lowers then to fill the car raises. I even put the car about 2" higher in the back ,and has not gone back down! So I know the shocks are good. New shocks up front. The car is on factory 16" rims with michellin tires. Could worn bushings cause this car to make this noise going over a bump like I am driving with olny rims? The tops of the rear shock mounts look to be in good shape and not cracked. Thanks for your feed back..
Old Jun 15, 2008 | 07:12 PM
_Adrian_'s Avatar
'93 600SEL
Hmm...
To my understanding the spheres are the actual schock abosorbing unit.
so correct me if im wrong but if the hydraulic shock is pressurized, the mineral fluid is very hard to compress if the nitrogen has leaked through the membrane.
Unless you got a problem with the leveling valve problem...
Which im sure its not unheard of.
Old Jun 19, 2008 | 09:58 AM
Jim's500E's Avatar
The reservoir under the hood shouldn't actually be 'full'...only up to the top rib is considered full, there has to be some air space in the res. so it self-bleeds any air off the return line.
Its VERY common for the spheres to go bad, and its easy to replace them in the driveway. They'll 'clunk' letting you know its time to change. Change to new fluid too when you do this. That V12 site is a great place to get familair with repairing/maintaining the system.
Old Jun 30, 2008 | 01:08 AM
1998 S500
I replaced the accumulators about 9 months ago. Also put new shocks on the front about 2 months ago. When I go over a bump feels like I dont even have tires on the car. Thanks for your help =]
