ABS ASR Light
95 S500
Whenever the brakes are tapped lightly, sometimes my ABS and ASR? lights go on, and the car goes into safety/limp mode.... it runs like this until i turn the car off, and the car resets itself...
If i'm more definitive in my braking at high speeds, its fine... it doesn't trip... but usually happens at slower speeds... (40 mph or less) i'm pretty sure its something electrical... or a sensor or something...
what does the ASR light mean? I was reading on the bmw forums, and a guy had a similar problem, and was told he had a problem with his MAF and it would trigger the ABS/DSC light to come on...
that sound right? any other suggestions of what it could be? thanx guys...
hope it helps you.Seems since it is related to brake pedal use and brake pedal applied pressure that it could be the same issue
http://www.autohausaz.com/search/pro...Light%20Switch
easy fix
ohlord
easy fix
ohlord
got it... i'll look into that... thanx, brother...
easy fix
ohlord
I was wondering would you happen to know how to take that carpeted panel off, underneath the dash and steering wheel...
I have taken off the two screws underneath... the two near the parking brake release... and one more inside the vent, facing the door... i was able to loosen everything on the bottom, but it seems to be connected to something at the steering column area.... are there any screws i'm missing? near the center console side? are they clips i have to force out?
i have labeled the places i have removed screws from....
i've searched 4 different forums, google, yahoo... can't find anything on taking the panel off... everyone just says its a PITA, good luck... please let me know if anyone can help me out with this... thanx!
