Inoperable speedometer, ABS & ASR lights on due to "crossed" jumpstart
The car runs fine. I think that there is something to do with a relais or a hidden fuse somewhere out of my sight.
In my oppinion when power arrives to the speedometer then everything is fixed.
Another user made the same mistake, I wonder how he solved the problem. I wrote him an e-mail asking for help.
I have just replaced all fuses (front and back) with new ones.
Problem still goes on.
No working speedometer gauge, no working fuel comsumption gauge and both ASR & ABS yellow lights on.
All the rest is working 100%
1. fuse is not firmly inserted.
2. drive around to see if computer will pick up the new message.
3. did you check out if the fuse you take out is blowed out or OK? If it was blowed out, then a fuse change should work. If not, maybe the system is burned.
good luck
"this is the rumored SECRET FUSE BOX everyone keeps talking about"
I am afraid I must concur with vilamoura. Reversing the polarity can do serious damage to the discrete components in these electronic control units.
Turning the power off and then on makes everything getting rigth.
MB mech. said a captor seems to be wrong.
I know this is a different problem, but could this one(sorry, I don't know the equivalent for the french word "sonde" (borer?)) be a captor problem ?
"this is the rumored SECRET FUSE BOX everyone keeps talking about"[/QUOTE]
Thanks very much!! I followed your advice and my problems were solved! My speedo is now working and the ABS light doesn't remain on after starting. Now I can take my trip worry free! Thanks again!
