S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
s320 cruise
Old Mar 3, 2010 | 12:58 PM
barry S320V's Avatar
1995 S320V
s320 cruise
I recently had a lot of work done on my 1995 s320 engine. new engine wireing loom, spark plug coils/igniters,I forget the correct name, and the dreaded leaking T conector on the firewall. The new coils finaly fixed the rough running problem. I got the done coils done at an independant shop as the Mercedes dealer seemed unable to fix the problem despite outrageous costs.
So last week I drove from Vancouver Canada to Palm Dessert California, about 2000 kilometers. I used the cruise control on the straight and relatively flat sections at about 120 kph. On two occasions the engine suddenly stopped, the srs light came on and no power. The first time I made a "dead stick" landing pulling over to the road side with no power. The car restarted right away. The second time I didn't pull over, I put the shifter in neutral and restarted the engine and continued on. Neadless to say this made the wife very nervous, and she volunteered to drive, not using the cruise control.
Has anone else had this happen, and if so found a fix??
Old Mar 6, 2010 | 05:25 AM
canary616's Avatar
I had the same thinh on my 1995 S 320 silver this case will repeated sevral time till you find no way of switching off and start again and you have to carry your car to the shop.
in my case I was lucky they found the cable is worn out and they chang it with new one and every thing back to normal.
the throttle actuator is very expencive about 1500$ new so check your actuator cable before become wrest the part # Part Number 0001414925
Old Mar 6, 2010 | 06:17 AM
canary616's Avatar
if that help you please lit me know
Old Mar 6, 2010 | 06:23 AM
canary616's Avatar
good luck
Old Mar 6, 2010 | 09:24 AM
napaAl's Avatar
1996 S320 SWB, 1998 S600
Thanks for the tips on anything S320. That looks like an electronic part.
I've lubricated my throttle cable at both ends, as well as return spring. I even felt a little smug after Toyotas debacle with a computer driven throttle, which will be a great system when the bugs get ironed out.
Old Mar 7, 2010 | 04:51 AM
1995 S320V
canary616
thanks for the information. The picture is of the throttle actuator I assume. I would like to fix it without spending another $1500. if possisble.
Old Mar 7, 2010 | 05:24 PM
rninpong09's Avatar
W140
If you open the throttle actuator unit, you will find a bunch of wire insulators are broken, you could clean and replace it with the new one, I done mind couple of years back and it give me no problem since. (The job is not quite difficult DIY type)
Before that time I done so many "dead stick landing" from this problem which initial focus on the break switch, but it is not.
Old Mar 9, 2010 | 12:41 PM
1995 S320V
RNINPONG09
did you replace the wires or did you wrap them with new insulation??
Old Mar 9, 2010 | 08:34 PM
rninpong09's Avatar
W140
I replace the whole bunch of them. You may need mil spec. wires or high temperature insulator wire for good measure. I think I have some link that show the details eventhough that is for 600 type, but for 320 it'll be just one control unit while 600 has two (left bank and right bank engine).
Old Mar 12, 2010 | 06:17 PM
rninpong09's Avatar
W140
Information related to the actuator rewire
Here is the information that will help you to do the job. http://v12uberalles.com/throttle_actuator_rewire.htm
Old Mar 13, 2010 | 05:06 PM
1995 S320V
impressive
I don't think I have the confidence to try to do this job. It is very involved.
I only have the one car so I can't take it off the road for as long as this would take. I will try everyk thing else before I make a decission.
Thanks for the information.
Old Mar 13, 2010 | 09:21 PM
napaAl's Avatar
If the wire insulation is breaking down, you could always try a short term repair by coating your wires with a urethane spray or silicone caulk.
