S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
NOS Sniper system for a m104 engine
Old Jan 26, 2012 | 08:57 AM
oldsinner111's Avatar
s320
If you got a 6 cylinder,and you want to out run V8s,a NOS Sniper universal system is a cheaper way of doing it.
This Kit is perfect. Remember use button after 3000 rpms to 6000,then let shift,or ASR will mess you up.
Old Jan 29, 2012 | 08:50 AM
s320
I forgot I have a 100 shot
Old Feb 4, 2012 | 09:46 AM
s320
update colder plugs
If you want to run a 100 shot like me,use 2 step colder plugs Autolite Racing Plug AR3911
Old Feb 20, 2012 | 04:12 PM
s320
I am now using stock plugs and timing.No problems colder plugs are a waste of money
Old Mar 3, 2012 | 02:38 PM
s320
Note* Running a 125 shot now.
Old Mar 10, 2012 | 08:37 AM
s320
I forgot and let a shift occur with nitrous,and transmission computer put me in neutral.I had to turn off engine and restart before it would drive.Thank God for computers.Any one needing help installing nitrous just ask me.
Old Mar 11, 2012 | 07:46 PM
MB_Fahrer's Avatar
Deleted
Nice work, any videos of it in action?
Old Mar 12, 2012 | 03:41 AM
s320
I should have a video by 2 week of April.The race is on March 31st.
Old Apr 13, 2012 | 07:06 PM
s320
still working bugs out of nitrous system.Blew fuse halfway down track but beat a mustang clearly in 1/8 mile finished 1/4 at 16.1.Faster than stock times of 17.
Old Oct 29, 2012 | 08:00 PM
michobebe's Avatar
W220 S500 2003 4Matic & W140 1998 S600 V12
Hey! Have you tried to dyno it to see how much torque would it make!?
Also, did you tune it in any way to have a good mix of NO and fuel or someone did it for you!?
I'm thinking of doing it to my m120 (M104 x 2) and I think that would be more appropriate that supercharging/tubocharging and their multiple thousands investement.
I wonder how the internals are coping with the extra power!
I think a 2 x 75 shots would be enough for me to get it from 400hp upto 550 hp
Mb_Fahrer I'm surprised you didn't tried it yet on one of your 600s or 73s!
Old Oct 30, 2012 | 05:17 AM
s320
hey Mich,a M120 running NOS would be awesome.As far as my internals they are good to 500hp.Serveral forced induction M104s running in that range.
I can't get a tune with a HFM engine.I'm running a little rich,better to be rich,than lean.
Your engine will be fine with a 150 shot.That should burn off the tires.remember don't spray until you reach 3,000 rpms.
Old Oct 30, 2012 | 08:55 AM
michobebe's Avatar
yea I see! the thing that still annoys me is not being able de deliver the N2O before a certain RPM (3000-6000) to spare the engine/tranny I guess these beast need to get moving from 1800 rpm and that's what I love about supercharged 55s engines. I'm thinking maybe 2 nitrous injection tips, one 50-75 shot as of 1800 rpm and another that kicks after 3000 and that adds another 50-75. As I can spend all day under 1800 rpm unless I'm pressed that way one could have tangible down to earth performance at low rpm starting from 1800, not only when racing above 3000 rpm which I rarely do.. matter of fact i don't recall redlining me engine more than once yet.
Well actually there are gradual delivery systems that already exist but I guess they would cost more that to double the spraying parts
Old Oct 30, 2012 | 09:41 AM
s320
I was wrong it 2000 with full throttle.Unless you purchase electronics,then you can appile at 3/4 throttle
Yes I spray from 2 grand to 6400,then let trans shift,then spray again
at 150 shot I'm running stock timing and regular spark plugs
Old Oct 30, 2012 | 11:05 AM
michobebe's Avatar
Are you running Dry or wet ?
Man if you're running 150 with no problem on one 6 cyl bank then on 2 banks that makes for 300 extra hp.. miammm
then with a 75% efficiency, that makes for arround 225 hp net increase.. So we're talking 625 hp !
Ohhh can't wait for a few days off.......
Old Oct 30, 2012 | 11:15 AM
s320
I run a wet system.Tap into fuel test at test port
