S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Disappearing water.
Old Jan 26, 2004 | 12:07 AM
amgmercedes's Avatar
Disappearing water.
My S600 is loosing water, after topping off the expansion tank, half an hour of driving has the water warning light in the dash coming on already. No visible signs of water leakage.
Filled the expansion tank, then left the car runninng in the driveway yesterday for about 45 mins, checked the expansion tank again, it is was already empty. Wierd thing is, there is no water underneath the car.
Where is the water going?
Old Jan 26, 2004 | 01:43 AM
guydewdney's Avatar
prob blown head gasket. water is being 'burnt'...(a bit like my cooking :p)
time to re-mortgage the house..
Old Jan 26, 2004 | 05:22 AM
I dont think so.
If the engine burns that much water in that little time, Im sure the engine would not be running as smoothly as it does. And there would surely be white smoke coming out of the exhaust.
Old Jan 26, 2004 | 10:09 AM
shmelvin's Avatar
none
Head gasket
guydewdney is correct these are the classic symptoms of a blown head gasket. There is one theory that an engine will run better with a bit of water in the mix. They used to sell a hydration unit that dropped water into carburetors that may be BS but it didn't hurt.
I had the exact same thing happen to a 351 Ford I was also in denial as it ran perfectly, it's a simple test have a radiator shop put a pressure test on the system. Do it soon because if water gets into the oil you can kiss the engine good-bye.
Good luck
Old Jan 26, 2004 | 10:12 AM
CME4BENZ's Avatar
All of the above
I would not mess around either. If it is still losing water after topping it off once I would have it checked out. How many miles are on it?
Old Jan 26, 2004 | 10:31 PM
The car has 40,000 km.
If I was burning 2 liters of water every 15kms, I dont think the engine would be running the way it does now.
Old Jan 27, 2004 | 01:37 AM
guydewdney's Avatar
the other possibility is a blown heater matritx.
lift all the carpets in the font of the car and check for damp / swimming pools
Old Jan 27, 2004 | 08:14 AM
Peter Guenther's Avatar
92 500sel/01 320e wag
Water loss
The cooling system on the 140 body is complex, the coolant runs thru the windshield washer tank, thru a line at the base of the windshield, the heater of course, and all 600s had a heater in the console for the rear seat. Search, search there are some deep wells under the carpets
