S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
S600 1995 will not start...help
Old 05-28-2015, 04:31 AM
Makuahine's Avatar
1995 s600 Mercedes
Exclamation S600 1995 will not start...help
Parked the car few hours later wouldn't start.
It cranks but doesn't turn over it almost does at times.
Idk what to do! We can't find a obd1 anywhere!
Car has 80,000
Old 05-29-2015, 03:17 AM
KNBS550's Avatar
Mercedes-Benz 2007 S550, 2012 S550 4-Matic, 2015 GL450
Your description sounds typical of a camshaft position sensor. Usually you can crank the engine, but no spark to fire up the engine.
Old 05-29-2015, 05:18 AM
Makuahine's Avatar
1995 s600 Mercedes
Yeah there is no spark.
How easy is a cam shaft to replace can I do myself?
Or should I bring to Mercedes?
Old 05-29-2015, 05:45 AM
Makuahine's Avatar
1995 s600 Mercedes
Best place to order parts from?
Old 05-31-2015, 01:53 AM
KNBS550's Avatar
I would go to autohausaz.com, pelicanparts.com, partsgeek.com, benzpartsforless.com. BTW, autohausaz.com kind of PO'd me when I had to return an air filter that wasn't even used and came from their warehouse with the box seal broken. The warehouse guy must have opened it to check before they shipped it out. Anyway, they charged me a restock fee. I minimize dealing with them if I can. I'm sure the others charge a restock fee, but they don't ship parts with the box already opened!!!
Old 05-31-2015, 07:05 PM
Makuahine's Avatar
1995 s600 Mercedes
New fuel pumps working
There is an engine spark but still wot start only crank?
Old 06-01-2015, 07:10 AM
burgca's Avatar
'97 S500 Coupe, 2016 AMG S63 Coupe, 2007 Audi Q7
Have you tried your other key? If the key gets out of synch the car will turnover but won't start. I have this problem with one key, it'll open and lock doors but can't start car.
Old 06-01-2015, 11:48 AM
Makuahine's Avatar
1995 s600 Mercedes
The other key we have doesn't start the car it's just the key fob
Old 06-01-2015, 03:33 PM
KNBS550's Avatar
Hi, you said earlier there was no spark. Now you said there is spark and it cranks, but it won't turn over? Also, based on your first message, it was running until you parked it? You've got a new fuel pump and spark, so the only thing that's missing is compression, but if it's cranking then it should be there???
Old 06-01-2015, 04:11 PM
Makuahine's Avatar
1995 s600 Mercedes
Yeah we've got a spark now there is no fuel pressure though. It'll crank but won't start
Old 06-08-2015, 07:53 AM
burgca's Avatar
If the key is out of synch you will not get fuel signal from the ECU , car will crank but will not start
Quick Reply: S600 1995 will not start...help
