S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Program Keyless remote
Old Nov 27, 2004 | 06:30 PM
ataie's Avatar
2007 Mercedes SL550 Sport
I couldn't find anything under this item so was wondering if anyone has the instruction for programing the keyless remote for a 1995 S420? thanks in advance.
Old Nov 28, 2004 | 09:22 AM
Peter Guenther's Avatar
92 500sel/01 320e wag
Resync
Aim remote at car, push button on remote, lock unlock with key!. Page 121 of owners manual
Old Dec 7, 2004 | 10:25 PM
ataie's Avatar
tried it - nothing happens.......
Old Dec 8, 2004 | 11:55 AM
s0vietbenz's Avatar
1995 w140 s500
you try getting new batteries?
Old Dec 8, 2004 | 11:14 PM
ataie's Avatar
it's a brand new remote, right from the dealer.
Old Dec 31, 2004 | 10:44 AM
wmercer's Avatar
W140 600SEL
One thought: Even as a brand new remote, the battery could be defective, or just run down. If you have not yet fixed this problem, try installing a new battery or take back to dealer. let us know what happens. thanks.
93 600SEL
Old Dec 31, 2004 | 11:54 AM
Non functioning remote
Look into the red window and push the button you should see a red flash if it works
Old Dec 31, 2004 | 02:08 PM
Remote
There were two versions in 94
1) push button on remote while aiming at sensor and then turn ignition on with key (1/94)
2) press remote button twice and turn key to position 2 (12/94)
or go back to dealer.
The previous suggestion of key in door is up to (12/93)
Old Jan 3, 2005 | 09:56 AM
ataie's Avatar
remote program 95 S420
hold button on remote, insert key in driver side lock, lock/unlock twice while holding down remote button, release button on remote. Then wait a few minutes, before the programing works.
I tried several times and nothing happened, then I come back an hour later and sure enough the remote works.....
dealer was lost and each service guy was giving a different way to do it. one said ignition, one said aim at rear view mirror, the part department said do the lock thing.
the range of the remote is about 12" (about 30 cm) from either front locks or rear trunk lock. not veryu good.
thanks to all for assistance
