S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Blown lower radiator hose (fingers crossed)
Old Jun 9, 2025 | 07:48 PM
Viking87's Avatar
1995 S420
So my highway trip ended in a cloud of steam on the side of the road. The over flow is still full of coolant but the top hose is empty. Fluid dripping from the lower passenger side. Came home on the flatbed.
I am hoping it is just a hose (haven't really looked too closely as was tired when I got home).
Is this something that can be repaired from underneath using just ramps (and by someone with limited mechanical experience)? Car temperature gauge went to hot before the steam poured out (was right after I turned on the heat).
If it isn't just a hose/clamp problem what would other suspects be? Stuck thermometer? Car heater exchange system?
Any experience or speculation is welcomed.
Old Jun 9, 2025 | 08:59 PM
ChrisHimself's Avatar
SPONSOR
11 E550, 16 AMG GTS, 13 S550
Yep you can replace it yourself from the bottom. These cars are ancient, stuffs gonna break. Replace whats broken and go from there.
I would replace both, inspect the sides of the radiator tanks for leaks, as well as the overflow tank/level sensor to make sure you're ok.
Upper hose
A1405000875
Lower hose
A1405000175
Overflow tank hose
1405000672
__________________
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
Old Jun 9, 2025 | 09:21 PM
Viking87's Avatar
1995 S420
Thanks for the specific answer. Top hose looked okay so hoping the clamp failed and it just popped off. If the hose failed I will replace them all.
Old Jun 10, 2025 | 02:43 AM
ygmn's Avatar
2015 E400 Sedan
So you turned heat on and then it got HOT and overheated?
Check the heater hoses.
Old Jun 10, 2025 | 07:18 AM
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
I would want to know why it failed...was the system over pressurized (like mine was)?
Old Jun 10, 2025 | 03:44 PM
Viking87's Avatar
1995 S420
I put it on the ramps but couldn't see much from underneath as didn't want to remove the cover protecting it from below.. Looked down from top and reached down and the hoses same in place in and in decent condition. Poured some water through and it came out way further back on the engine that the radiator/hoses.
Correction on my original comment the fluid overflow is empty as is the bottom hose. The water poured straight through and come out behind the front axles.
Any thoughts on what might have blown back there? Was a huge cloud of steam when she went (like the fluid was spraying on the exhaust manifolds). Think this is one for the garage but would like to give them some guidance/possibilities.
Old Jun 10, 2025 | 03:45 PM
Viking87's Avatar
1995 S420
No was already showing hot on the gauge before I tried the heat.
Steam was soon after but not sure if related (might have just been when she let go).
Old Jun 10, 2025 | 04:30 PM
Viking87's Avatar
1995 S420
Could this be my culprit?
Going to have to take it in to garage I guess.
Ruled out the hoses as leak is further back on the car.
Rear heater core
Rear heater core
Old Jun 11, 2025 | 01:33 PM
JohnLane's Avatar
222 S-65
OP diagnosis starts with figuring out where it is leaking from.
My diagnostic dice and Ouija board are not effective from great distances. Even the magic eight ball won’t help. Get ALL the panels off underneath and find where it is leaking. Or take it to a competent shop to do this for you.
Old Jun 11, 2025 | 02:22 PM
Obviously your skill set it not as high as many of the other Internet Mechanics @JohnLane . We prefer this like playing darts with drunken blind folks in a Graviton. Who needs facts to bother with an internet diagnosis? Please, get with the program. :-)
Old Jun 11, 2025 | 08:54 PM
JohnLane's Avatar
222 S-65
Oh... shoot. Duly noted. Carry on.
Old Jun 14, 2025 | 01:56 PM
Viking87's Avatar
1995 S420
Over pressurized system
I wonder if this was the cause. Thermostat is stuck shut, pressure/heat builds in engine, turning on the heat releases over pressurized coolant from the engine into the car heating system, something blows (hose or a clamp or other component), coolant sprays on exhaust manifold, steam cleaning of engine ensues.
Seems like a plausible scenario. Going to need a lift/mechanic to locate where the leak is. Just using another vehicle in the interim.
Old Jun 14, 2025 | 01:58 PM
Viking87's Avatar
1995 S420
Yes I agree.
Will figure out leak and f it is easily repaired.
Thinking of doing the thermostat at same time (will have to order a new one in advance).
Old Jun 21, 2025 | 11:00 AM
JohnLane's Avatar
222 S-65
OP did it overheat? If so do the thermostat. Otherwise.... all those fancy coolant hoses under the hood of your car are likely the same age.
Feel like playing whack a mole with hoses that fail one at a time over the next few years?
Lot more money and effort all at once but a big $$$ and time saver done once.
Old Jun 21, 2025 | 10:41 PM
Viking87's Avatar
1995 S420
Yes it overheated within 20 minutes of starting. The hoses (that I can see easily) seem to be in good condition so still think it maybe blew it off. Still not sure where it is leaking from. Going to order a thermostat before it goes to the garage. Yes if hoses are getting sketchy I will order them all and get them replaced.
Old Jun 27, 2025 | 03:56 PM
Viking87's Avatar
1995 S420
I found where the leak happened. (picture related)
Hard to get at so will leave for the professionals. Might require taking off some other hoses.
Blown hose/connector
The connector might be too damaged to reattach. Guess I will need one of these. Will order with the thermostat.
Thanks for the diagnostics/input.
Old Jun 28, 2025 | 04:30 AM
SPONSOR
wow its funny how across every Mercedes decades apart they always have some complicated nightmare coolant hose at the firewall that goes out before any of the main ones
__________________
Old Aug 10, 2025 | 04:50 PM
Viking87's Avatar
1995 S420
Final report
Mechanic replaced the blown heater hose, did a flush and got the proper thermostat installed.
Car still overheating. Old tow truck guy who helped me said it sounds like a blown head gasket. Did some research and am inclined to agree. Any thoughts/experience with BAR's Head Gasket repair additive? Worth a try I would think. I know this may trigger some purists who would say just change them but that is far beyond my abilities and would be major $$$.
Thanks for all the input.
Old Aug 14, 2025 | 01:12 AM
JohnLane's Avatar
222 S-65
OP more real diagnosis is in order. A test to see if exhaust is getting into the cooling system is a good start. Then apply pressure to individual cylinders with the cooling system full and bled. The cylinder that leaks will push coolant out.
Bars Leak has no business in your engine!!!!
Sure the cooling system is properly bled? They can be a pain to get all the air out... esp when a hose lets go.
Old Aug 23, 2025 | 02:42 PM
Viking87's Avatar
1995 S420
Thanks for the reply. Haven't done anything yet with the engine. I am pretty sure that the hot gasses from one of the cylinders are getting into the cooling system.
The car worked fine driving 50 km each way to work for months then one day the temperature gauge went right up and a cooling system part failed. The car hasn't been used since (other that back and forth to garage for other work described in thread).
As to whether or not it is bled fully the garage said they have a machine to draw out air while it is being filled with antifreeze so would assume that is the case.
Don't have the ability or resources right now to take anything apart and physically repair a head gasket.
As this is a recent problem I thought it might be a good candidate for the leak treatment.
Even if it resolved the problem for the time being or for short distances with the car. Can just use the car as a town car (ten minutes round trip) and use another vehicle for longer trips.
Have you had a bad experience with Bars or is that just a general opinion against those products?
Old Sep 14, 2025 | 08:08 PM
Viking87's Avatar
1995 S420
Well the car has stopped overheating. Except that is because it stalls after about 10 minutes once it warms up to about 80 on the gauge. Did confirm the electric fans do still come on when called for.
Still think it is a leaking gasket. It is not consuming any antifreeze and starts and works as normal when started up until the engine warms up. Check engine light was on prior to all these problems. I purchased a code reader but it won't work because there is a connection stuck open somewhere in the electrical system. This vehicle worked like it should for thousands or kilometers then just failed suddenly.
Has anyone else experienced this symptom (stalling after warming up)?
Any arm chair mechanic opinions appreciated.
