Rear window tint looks puurple (brand new)
1 Post
2002 S430
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
Hi, Just bought a 2002 S430 with 12000 miles w/ CPO. The dealer tinted the car for me and it looks great. The only thing is the back window looks purple at certain angles. The side windows always look black, but the rear is purple in color, not like the purple when tint goes bad, but just not a deep rich black like the side windows. The dealer used the same tint on all the windows. The only thing I can think of is that it has something with the UV protection in the glass the same stuff that affects the EZ Pass from working.
Any thoughts would be great thanks.
patrickcain (02-15-2021)
1 Post
CLS 63 S AMG , s500,clk550
I think if you have the infrared glass that has the factory bluish tint then it will look purple if you go with a 35% tint. If you get 20% or below then that purple color cannot be seen.
Has anyone ever removed tint from their S class? I know these windows easily get scratched.
1 Post
02' brabus modified ML500,05' Lambor Gallardo, 02' CLK
look from a side view, you folks can see a mesh window-heat system on the glass, those little wires help defrost the back window, that's the reason why you see different color, cause of the reflection of the wires, cheer
1 Post
W220 M113K
1 Post
lol im about to do 15 or 20's in the front rite now i have 20s's on the back windshield and on the rear passangers i have .25 (which is pretty much one layer of 20 and one layer of 5) im not sure which one to do in the front.. any suggestions on which ones for front windows?
LX470
I kept scratching my tints, and eventually my new tint guy said the felt will prevent any scratching, and sure enough, he was right. He's a fantastic tint guy!
1 Post
2002 S430
Before you get the windows tinted, you might want to get the plastic trim (on the bottom inside glass) covered in felt, so every time you roll the windows up or down, the tint will br protected.
LX470
Ok, there are 2 parts to this trim.
The first part goes around the top and sides, and that is covered in felt, but the bottom part is just this long black piece of plastic, and that is the culprit when it comes to scratching. If you pull the door panel away from the door ever so slightly, you will see it.
If it's covered in felt, then you are golden, but if not, just go to a crafts store, and find the thinnest piece of felt, cut it into strips and hot glue those suckers on to the plastic bars.
Once you glueit about a day or two to completely dry, then put the plastic strips back into the door panel.
The easiest way I found how to get the panel seperated is to pry where the door locks are, but if you are unsure or don't want to risk breaking anything, find a tint guy who knows how to do this.
