No radio, no navigation
LX470
I was driving back from Manhattan tonight and as I lowered the volume, the radio and navigation froze. No sound, no nothing. The screen is still lit and I can toggle the buttons with the little round knob, but that's it. Every other button won't work. Any suggestions would be appreciated.
02 S500 Sport
When your PC Freezez, what do you do, you restart it.
Try restarting the Comm system.
LX470
2005 S55
Thanks!!
2005 S55
2005 S55
Anyway, I will be doing this in the afternoon .. I am worried though because what I did get from just disconnecting the lead was an ABS light, Brake Assist malfunction warning, Airmatic malfunction warning and ESP malfunction warning (take car to workshop) .. so, not quite what I had hoped.
I'm hoping disconnecting the battery totally for a few minutes will reset everything .. and I'm really hoping I didn't just create a bunch of problems where there were none!
2005 S500 4-Matic, 1978 450SL
Shaw01
After you do it, you may need this too: http://www.benzworld.org/forums/w220...ml#post2216730
Benzdriver9, if you find some things not working as they should, you may need it too.
LX470
Shaw01
Once the positive terminal is disconnected, the battery is disconnected. Disconnecting the negative is a waste of time. I'm not sure what your dad meant, but one lead is sufficient.
2005 S55
Everything is back to working, of course it did not fix the radio problem that I did all this for so (did not totally reset that either I dont' think .. all presets and options still same on radio) .. so it looks like off to the dealer I go
![mercy](https://mbworld.org/forums/images/smilies/mecry.gif)
![hammer](https://mbworld.org/forums/images/smilies/bonk.gif)
![Nonono](https://mbworld.org/forums/images/smilies/nonono2.gif)
