brakes
http://cgi.ebay.com/ebaymotors/Kspor...spagenameZWD1V
Looks nice with 8 piston and 13" rotor, You already got bigger wheels so fitment will be no problem, just your stock front caliper and rotor will NOT fit to your rear brake system, you may find some used AMG rear caliper and rotor from ebay. it may fit !!
You could do it, but you'd have to change your entire rear hub assy, which includes the E-brake assy and all.. Then, you will need Rear rotors to fit.
This can only be possible if you used a set-up from a car that already has big rear brakes like the S600 or Some of the later AMG's an get the entire set-up mentioned above and retrofit it to fit your car.
Ken is right.. all of this would be 98% for show, and 2% for Go. ( or stop in this case..LOL )
Either way.. it's not worth it. and is a major undertaking but i believe it is entirely possible.
horsepower has almost nothing to do with braking power, it's all about weight and speed.
Unless of course your applying the gas and also hitting the brake at the same time, but i usually call this the 1-2-3 steps for a standstill burnout.
bigger brakes on a S-class is a good idea weither in a S280 from europe or Asia or a S500 in the US. the lightest s-class weights at least 4000 lbs, that's alot.
bigger brakes also help decrease fade when compared to smaller ones.
