OEM lug bolts
I keep a set in my trunk because they are the only lugs that work for my spare which is factory. ( good advice for folks who have A/M wheels ).
The (free) streets in the entire N/E aren't great, but unless you plan on 4 wheeling on a lot of side roads, the main roads are pretty wheel friendly. It has been a few months since the last big snow so most of the holes have been filled with asphalt by now.
I am the godfather to my niece so I have to be there. I will be in NY on June 20th for a few days. Yeah I know most of the roads are ok but on big dips they rub a liitle bit and I just put tires all the way around which set me back around $1,600 plus I will have a full car and see no need to wearing out the tires on a 2k mile total trip. the OEM tires are brand new and personally it is a much smoother ride than the 20's. I just hit me today that the oem lugs are know where to be found. so i need to order a set pretty soon to be ready for the trip. i decided to drive since on the way back i have a business meeting in PA so I thought why not knockout two birds with one stone.
Check in this weekend lie sat. night i should have something if you haven;t found what you need by then.
Thanks my06clk i will log back on for any updates...
no lug bolts on this website
45mm is longer than a 1.5" by about .2inch. a 1.50 in shank would be a 38mm.
I an on my way back home now so I will give you a good measurement.
The overall length is important, but you need to make sure you have enought threads on the shank.
I'l check back ater.
A buck a piece is pretty cheap. I'd think twice about using bolts of unknown quality on my wheels. Those RAD dacromet-plated lug bolts in the earlier link are OEM quality.
ANyway.
Jfendis430, I measured my factory bolts an they are 45mm shank length 20mm of which are threads at 1.50 pitch. They are also ball seat type.
I think you will be okay with the bolts you found on Ebay.
Thanks for the measurement I will keep you posted once they arrive and fit.
Thats you right?
http://www.carsandtuning.org/wp-cont...ng-big-car.jpg
Thats you right?
