722.6 trans flush and filter pix
1 Post
2003 S500, 03 C240, 03 E320, 03 tahoe
here are the pics of the transmission service that i did last weekend.14 litres of MB synthetic fluid,new filter and seals.52k miles on this trans.judge for yourself,it was time to service this trans.i dont understand MB's policy of lifetime fluid/filters.if you have any intention of driving your Benz for a long time than this service is necessary.
![](http://i515.photobucket.com/albums/t353/AH1W-COBRA/03S500-7.jpg)
![](http://i515.photobucket.com/albums/t353/AH1W-COBRA/03S500-8.jpg)
![](http://i515.photobucket.com/albums/t353/AH1W-COBRA/03S500-10.jpg)
![](http://i515.photobucket.com/albums/t353/AH1W-COBRA/03S500-9.jpg)
![](http://i515.photobucket.com/albums/t353/AH1W-COBRA/03S500-11.jpg)
![](http://i515.photobucket.com/albums/t353/AH1W-COBRA/03S500-12.jpg)
I had my S600 fluid changed at my local dealer a few months ago. They used a BG brand fluid machine to exchange all of the fluid including the torque converter. The shift quality isn't any different and sometimes it seems like the tranny is slipping now but I may be imagining it.
1 Post
what type of fluid?
96 and 08 911 turbos
When I did the fluid change on my 210 Eclass with the same tranny, I could only get about 3 or 3.5 quarts out due to no access to the torque converter.
Does the S have a TC drain plug? If not, why so much fluid? does it have a bigger pan or something?
my car has the 5spd and 52K miles just like the S500 in this thread. I have no idea which fluid was used but I can only assume that the tech used the correct spec fluid for the car.
1 Post
next time you do the service
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
Fopi C55 (02-24-2018)
1 Post
im sure he did
E90 N54 & W251
drop the pan and do the filter as before .after reassembly you add initial 5 litres,then start the vehicle and with the trans cooler return line removed from the trans and placed in a catch container you do three cycles of recovering 3 litres and adding 3 litres.at the end i had clear red fluid coming into the catch container and the entire system was flushed.no need to remove the converter drain whether it exists or not.ive used this method on all types of vehicles.this is the star library exact procedure.i can post it if anyone wants to refer to it.![drive](https://mbworld.org/forums/images/smilies/driving.gif)
Which side is the trans cooler return line? Driver side or passenger?
I really like your method. Initally I was planning on dropping the pan and filter, add 4 quarts (depending on how much came out), drive a bit then siphon out and replace another 4 quarts to dilute the dirty fluid. Your method is much more effective.
Thanks!
Plz post it
1 Post
passenger side
Hey Cobra,
Thanks!
Thanks!
i did the samething instead i used the new amsoil atf fluid which is mb approved for pretty much all there transmissions.
a full system flush 14quarts total as well.
fluid, filter and gasket cost me $150 and the tranny flush at friends shop $50.
$200 to me is a hell of alot better then spending $5grand for a tranny
