Car failure ABS, ESP, BAS help
Old Jan 29, 2009 | 11:54 PM
Arlen777's Avatar
2002 Mercedes S 430(GONE), 2001 E320(GONE), 2007 S550(GONE), 2009 BMW X6(GONE), 2014 S550
2 months ago i replaced rotors and brakes but forgot to replace brake sensors, 2 weeks later my brake pedal fall down when i push it and vibrating like if the abs is working, i thought it is because of brake sensors, so i replaced them message didnt go away, then while changing oil my friend on firestone told me that i have a leak in brake master cylinder, so i replaced it, error mesage still on, today asked him to diagnose my car, and it showed me this code C1101 Right Front Axle bla-bla-bla, anybody had this problem?
Old Jan 30, 2009 | 01:09 AM
whoover's Avatar
'19 E63S sedan
Sounds like you have a failure in your ABS, a very important bla-bla-bla. You can keep screwing with your brakes until you kill yourself, or take it to a competent mechanic.
Old Jan 30, 2009 | 01:24 AM
ohlord's Avatar
I.E.
Not firestone.
Not for oil changes and most certainly not for MB brakes.
Right Front Axle VSS Circuit Fault
mb code
you need to inspect the circuit,find the fault and get it repaired.
Any good mb indie shop with a fully upgraded sds machine will diagnose it quickly,and then you decide if you want to do the diy or leave it to them.
Old Jan 30, 2009 | 01:56 PM
S-Clusiv's Avatar
Whatever there's gas in...
This happened to me when I forgot to bleed my brake line, after I did that all my problems were gone.
Old Jan 30, 2009 | 05:36 PM
Arlen777's Avatar
I asked if anybody had such problem and what it was exactly like fuse or rely or smth, i know that its ABS failure
Old Jan 30, 2009 | 05:37 PM
Arlen777's Avatar
Originally Posted by ohlord
Not firestone.
mb code
There is nothing wrong about Firestone changing oil, and i didn say i firestone replaced my brakes
Old Jan 30, 2009 | 05:38 PM
Arlen777's Avatar
Sorry for my english, what do u mean by bleed brake line?
Old Jan 30, 2009 | 07:38 PM
whoover's Avatar
'19 E63S sedan
Did you change the master cylinder yourself? If so, you had to have bled the lines, right? Get the air out by pumping new fluid through to each caliper, farthest first, until there are no bubbles.
Old Jan 30, 2009 | 08:57 PM
Arlen777's Avatar
No i did it in shop so they did all the necessary stuff
Old Jan 31, 2009 | 07:57 AM
blas0827's Avatar
none
well you say the light was on before you replaced the master cylinder right if so you need the right vss
Old Jan 31, 2009 | 05:57 PM
Arlen777's Avatar
ABS, ESP BAS lights were on before and after whats vss?
Old Jan 31, 2009 | 06:02 PM
whoover's Avatar
'19 E63S sedan
Vehicle speed sensor. All those systems rely on it for proper function. If you don't know, you should not be driving the car. It's an accident waiting to happen.
