ipod hookup in a 2001 s500
Old Feb 6, 2009 | 09:20 PM
inkslinger's Avatar
2001 s 500
does anybody know the easiest way to hook up an ipod in my 2001 s500?
Old Feb 7, 2009 | 08:26 PM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
The easiest way (with crappy sound) is an FM over-the-air transmitter; a slightly better alternative is an FM modulator that splices into the FM antenna. Still not good, but easy and cheap. Harman-Kardon makes such a device (Drive+Play) that also has a screen and controls.
The best way will be with the D2B version of the Dension Gateway 500; see https://mbworld.org/forums/audio-ele...mentation.html - read carefully for the differences between the D2B version and the MOST version. You won't have song title readout, but you can select albums, artists, playlists and songs from the iPod itself while controlling scrolling and volume from the steering wheel. The D2B installation is MUCH simpler than the MOST installation (no fiber optic changes are necessary in the trunk for D2B). You can download the installation manual and user manual from the Dension site links in the writeup.
Old Feb 8, 2009 | 12:18 PM
LAWYER2's Avatar
15' W222
cheapest fast way, is to get the tape player adapter. It sounds fine, and you can hide that cord behind the console cover by loosening a few screws
Old Feb 8, 2009 | 01:32 PM
Jezza's Avatar
S430, SL500
Exactly what i have done, sounds absolutely spot on. The only visible wire is about 1cm long between the bit that closes and the wood trim panel.
