Amsoil best syntetic oil for our cars.
Old Feb 18, 2009 | 09:37 PM
Oxygen's Avatar
W220 S65 AMG
Best, better, good -- what ever...
I ran Royal Purple XPR in my car for like 5,000 miles... just changed it to Mobil 1... car does the same thing it's always done - starts and stops.
Old Feb 18, 2009 | 09:44 PM
S5LorinserF1's Avatar
2003 Mercedes S500 Lorinser
Originally Posted by SL2003driver
Do some used oil analysis with both the M1 and Amsoil and let us all know what you find.
i will do just that...will update in 3000miles
Old Feb 18, 2009 | 09:56 PM
Gondon's Avatar
02 S500 Sport
LOL Poor Nick getting attacked in every direction
Best Test is when your 1 CL behind and go like WTF with that look on your face
Lets pour some AmSoil down your throat HAHAHAHHAHHHAHAHAHHA
Old Feb 18, 2009 | 10:00 PM
C43AMG's Avatar
Veteran: Army
98 Black C43 , 12’ ML 350 Blutec
even mobil stated amsoil syntetic was superior..
Can you produce documentation of this?I would like to forward it to my aunt who has 35+ patents with Mobil Oil.
http://www.cardisllc.com/
Old Feb 18, 2009 | 10:33 PM
can your aunt do anaylsis of the two oils to see which one performs better. ill put up the funding if they could test Mobil 1 0w-40 euro formula vs Amsoil 5w-40 euro formula.
Old Feb 18, 2009 | 10:36 PM
im not geting attacked you moron these guys could be right but i just wanna know which oil is better.
Condom if you cant add anything knowledgeful dont post your seriously starting to bug me... you dont want me to knock you out with a smack the next i see you and you know i could very easily do it
Old Feb 18, 2009 | 11:04 PM
  #32
Untertürkheim's Avatar
I would just say to research what MB says about 229.5 vs 229.51, and read what I said above. Why would an oil with less additives be better?
Old Feb 18, 2009 | 11:11 PM
  #33
ok here are some oil analyis companies. which one would be the best for testing three independent oils.
i would be testing mobil 1, Royal Purple and Amsoil
http://www.polarislabs1.com/oil-analysis.htm#engines
or
http://www.testoil.com/
or
http://www.oillab.com/bestoil.html
Old Feb 18, 2009 | 11:13 PM
  #34
or
or
I like Blackstone Labs...
Why not try Valvoline and Liquimoly too?
Old Feb 18, 2009 | 11:19 PM
  #35
ok blackstone labs looks good also
is this test sufficient enough??
http://www.blackstone-labs.com/standard_analysis.html
Old Feb 18, 2009 | 11:23 PM
  #36
m4xm1l10n's Avatar
BMW F02 (750Li) F10 (550i)
You are not trying to find out , you clearly stated that amsoil is the best there is , and how would you know that ? all your fields of feedback proves NADA !!!!!
Old Feb 18, 2009 | 11:26 PM
  #37
No, if you really want to know how well the oil is holding up, you at least need to add a TBN analysis on to that. It might also be helpful to know what the 100C viscosity is so you know the viscosity in the engine and how much it changed from new...but TBN is most important.
Old Feb 18, 2009 | 11:27 PM
  #38
your right it doesnt prove shat until i get the testing done.
  #39
RedG's Avatar
a g
Amway Amsoil
Both are good quality companies
Originally Posted by Untertürkheim
229.51 is only for Bluetec models (diesel with DPF), and not approved for use in any other models, especially gasoline. So unless you have a S320/400/420CDI with DPF. Since you are probably in the US, it is not the case.
If the oil was so good it would not void your warranty, and would have the proper approval.
The oil itself will NOT void the warranty and if mercedes benz and the dealership wants to say it is the cause of the failure they have to prove it.
Yes, that test is sufficient. Though whatever tests you use just use the same for all three MB1, RP, and AMSoil. And try as you might to no change driving habits either, that will lend some validity to the tests also.
Old Feb 18, 2009 | 11:28 PM
  #40
ok so RedG the standard testing will be fine correct??
so the TBN testing wont be needed right??
wait i was gonna send in brand new samples of each oil to the companies to be done for testing??
does it matter if i send in new or should i save used samples of each after 3000 miles of use??
Old Feb 18, 2009 | 11:32 PM
  #41
If you have an oil-related problem and are not using an approved oil, there is nothing to prove.
Get the TBN, that will tell you how well the additive package is holding up.
Old Feb 18, 2009 | 11:56 PM
  #42
RedG's Avatar
a g
Well if you say an oil related problem sure, but you would know as well as anyone it typically isn't an oil related problem for the engine failure. Either way, yes, they still have to prove it was the oil's fault and not other mechanical failures.
Old Feb 19, 2009 | 08:22 AM
  #43
Quadcammer's Avatar
96 and 08 911 turbos
take a look at german Castrol 0w-30. Its MB approved, and the UOAs have been better than Mobil 1.
Either way, for the guys with 500s, your engine is not terribly hard on oil. Even the cheapest synthetic would be fine if you change it every 2-2.5k (huge waste of money if you ask me).
Old Feb 19, 2009 | 08:24 AM
  #44
MRAMG1's Avatar
S600, GL450, GLC 43
As I have said NUMEROUS time before WHY would you want to use anything else besides Mobil 1
It works GRAET
It meets ALL requirements
Its cheap
Its readily available
Note: Amsoil is a better product, BARELY but real world results it shows NO difference between the two, aka temperature Mobil 1 is good to 520 degrees, Amsoil is good to 525. NO REAL world drifference here guys.By the way, I made those numbers up as I have lost the actual numbers over the years, but they show the difference my friends.
My ex-crew chief worked at the Gulf research lab here in PA that did oil testing and Mobil 1 was as good as ALL the other oils in their testing.
Oh well I am really tired of this issue so enough said. Good luck to all, but I know I will stay with what works
See yeah
PS: ALL oils sold in the US now must meet the reduced phosphurous levels due to emissions and as such NONE of them are as good as they use to be, FYI
Old Feb 19, 2009 | 08:27 AM
  #45
C43AMG's Avatar
Veteran: Army
I provided the link to her website.Send her a e-mail and ask away.
Old Feb 19, 2009 | 08:48 AM
  #46
Gondon's Avatar
02 S500 Sport
LOL who you kidding you live for this ****.
p.s you made me into a prankster
Old Feb 19, 2009 | 10:27 AM
  #47
SL2003driver's Avatar
CLS63, GLK350
I suggest you go to www.bobistheoilguy.com That is where all the oil guys hangout. They use a lot of Amsoil and Mobil 1 and have used oil analysis to prove long term drain results. They can tell you about the best type of analysis test. Good luck and keep us posted. I think we all want to do the best we can for our cars.
Old Feb 19, 2009 | 10:53 AM
  #48
~CL500~'s Avatar
E90 N54 & W251
Since we're on the topic of oil, I figured I'd post this writeup:
http://www.ferrarichat.com/forum/faq...=haas_articles
Although it's really not a brand comparison, more like oil 101; It is by far the most detailed and thorough article I have ever seen on oil viscosity. It's very long, but worth the read if you have the time. Enjoy.
Old Feb 19, 2009 | 11:25 AM
  #49
whoover's Avatar
'19 E63S sedan
That brings up a question I've had for a while. There are quite a few 229.5 oils, all 0W-30 or 5W-30 that are approved for regular MB engines but not AMG.
Is there something specific about AMG engines that require -40 weight lubrication or is AMG just more conservative about high-temperature viscosity? If it's the latter, I'd be inclined to go with the AMG recommendations even in a non-AMG MB, but not knowing what's behind the prohibition I really don't know. I do know the dealers use Mobil 1 0W-40 in all gasoline engines, but that is probably to simplify stocking.
Anybody know for sure why the AMG requirements are different?
Old Feb 19, 2009 | 11:54 AM
  #50
Quadcammer's Avatar
Id imagine that AMG builds it engines a bit looser than the standard variants. This is all speculation, but I'd imagine they run slightly larger bearing clearance, ring gaps (especially on blown models), etc. In addition, these cars are generally driven harder which means higher oil temps.
This is just a guess, but I'd imagine any of the 229.3/.5 would work fine in an AMG engine, but since M1 0w-40 is easy to find, there is no reason not to use it.
I would feel very comfortable using GC 0w-30 in an AMG engine as its a quite thick 30wt oil.
