s65 tachometer??
2003 Mercedes S500 Lorinser
s65 tachometer??
my cousin at dealer can get me a new s65 tachometer for realitively free. from the 03-06 models.
Will this direct fit into my car and will it just need to be reprogrammed for the old miles??
If it does i would open the casing and black out the biturbo amg lettering.
96 and 08 911 turbos
any reason why you want the S65 tach?
If you black out the amg/ bi turbo thing, all you get is a tach without a redline.
If you are looking to get the 220mph speedo, I think thats a bit ricey since you car doesn't have a prayer of doing over 180mph.
04 S430 (sold),05 X5 4.4i, 02 325i, 87 560SL, 85 Alfa Romeo
Electronic governing wont even let it get anywhere near that even, 130ish tops.. if that. Then where? on the turnpike? yeah right.
I got my tank to 107ish for about three minutes once and I got seasick.
I want it because its free first of all. second its says 220 on it which look pretty cool.
My car has the limiter removed ive got it up to 167 so far. I dont think 180 should be a problem with my mods and the dyno tune this sat.
Anyways i might have TVT do some engine boring for me next month up to 5.7 or 6.0 displacement for not that much.
That sort of upgrade costs about $15-$20k if done by renntech or brabus (if not more). Even if TVT does it for half of that, you are using 1/4 to 1/3 of the value of your car to increase hp marginally.
The 220 MPH speedometer is not linear. 80 MPH is at 12 o'clock and the spacing is more compressed above 100 MPH. Is anyone sure this is handled by the speedometer and not the cluster or the ECU?
I have a feeling the electronics in the cluster interpret the speed from the VSS or wheel speed sensors and then display the correct speed for that type of cluster.
yea your right that brabus and renntech completely overkill for 15k-20k. thats crazy.
there are quality shops out there that bore engines more then renntech or brabus do and for a 1/4 of the price. to bring the 5.0 to a 6.0 with upgraded internals/titanium parts and new pistons could cost roughly 5-6grand. with that you get over 100hp and the engine remains NA. im not really that much of a fan of superchargers.
Again the tachometer is Free so why not install it.
2. why would replace your rods?
3. I do not believe that a reputable shop will provide you with high quality forged pistons, with pins, machine work, assembly, and engine removal/replacement for $3.5k to $5k. I can almost guarantee it will be double that.
4. To go from 5.0 liters to 6.0 liters, you will need to resleeve the block, which further increases the expense (talking bore only. If you want to increase the stroke as well, you then need a new crank and new rods). Bottom line, either one will add thousands to the price.
5. I strongly doubt that you will gain 100bhp from a 1 liter increase in engine displacement. Your engine currently makes 60bhp per liter. Aside from some unshrouding of the valves, there will really be no additional engine efficiency. Furthermore, by using larger bores, you will have heavier pistons, which will increase reciprocating weight, which is a drag on power.
brabus 5.8 upgrade nets 400hp to a stock s500.
and your right with the price i was way off.. Talked to the guys and it will cost between 8-9grand for a completey rebuild of the enigne. and yes it will need to be sleeved but thats not a problem. would take about a month of down time.
looking just to get the heads taken care of now along with aggressive schrick camshafts and thats were the mods will stop until the spring with i pick up the vette.
cluster for usa. Tachometer for germany.
I see Dimitry has been texting you that fruit. no hes not stealing it. Hes a head tech at soverign mercedes. He has a hookup straight from germany for the parts.
That upgrade involves a new block, bored and stroked, new crank, pistons, heads and cams. Plus electronics. What do you think that would cost? It's loony to consider putting significant money into S500 engine mods, which will only reduce any residual resale value, when an upgrade to an S55 or S65 can be had for less. Don't forget that even a 2001 N/A S55 had brake, suspension and transmission mods to go along with the 354 HP engine. At 400 HP you'd be naive to expect the car (and you) to stay in one piece without brake, suspension and powertrain mods as well.
But it's your car so enjoy yourself.
W220 S65 AMG
Well I wanted the AMG cluster for a long time now, so have him hook me up aswell... or just give me the one he's giving you and I'll hook you up with something.
02 S500 Sport
I haven't talked to Oxygen since Saturday and you can ask Oxygen that yourself.
B4 you go and talk **** get your facts straight.
He simply assumed it was your cousin cause you all told us that in the shop that he got the spindles for you and hes the head tech.
Now shut up Dikfor and go show me that *** can on your car ahah
[QUOTE=Oxygen;3373502]Yes... I talk to Dima... you have my number too if you feel left out bro!
It allright you guys can enjoy each other lol
Ill see if i can get you another one.. cause im def putting this one in my car.
whoover your right its pointless but i dont want a s55 or s65 im getting a vette in spring. The 500 is my cruiser/all season car since its 4matic. I just wanna keep it up to date with HP/TQ since all these new cars are at least pushing 300-375hp.
yo ski trip two weeks at Okemo in Vermont??
i got biaches down for it..gondon,oxygen you guys down i got some of my boys pulling thru also.
this is a no wetback/porchmonkey event
