removing rear discs on my 2002 S500
W220
The other day I had a reply back on how to remove the rear pads. Turned out that it was only 1 pin to remove on my brakes against what was being suggested i.e. 2 pins. Now that I managed to do that I now want to have a go at the rear discs. Would I be correct in saying that it is the 2 18mm bolts at the back of the caliper that need to be removed to take the caliper off?
04 S430 (sold),05 X5 4.4i, 02 325i, 87 560SL, 85 Alfa Romeo
There are two pins BTW but that only removes the caliper from the support so you can change the pads.
If you are taking of the rotor, you need to remove the caliper from the support then remove the support via the two bolts.
It is much harder to remove the support if the caliper is still attached.
Remember. Its the suppot that overlaps the rotor not the caliper itself.
That's my fault. 2 pins in the front, 1 in the back. Yes you are correct, once you remove the bolts, all you need is a large phillip screw driver to remove disc retaining screw, and you can pry the disc off. Be sure emergency brakes are off.
W220
Thanks for all the responses folks
However excuse my ignorance but when you say remember to make sure the emergency brakes are off, what do you mean by this
Cheers
Cheers
The parking break works by contacting a small brake shoe inside the drum that's part of the rear rotor. People forget to release their parking brake and can't figure out why the rotor won't budge.
also dont forget to decompress the caliper a little bit to take it off the rotor,
theres also a common case where the rotor might be alittle hard to take off due to a little rust build up arounf the center hub
my technic is to spray WD-40 around the hub and then with a hammer hit it around the rotor (not the disc part because if your not changing your rotrs can damage it if your just replace pads) and the vibrations should cause it to wiggle and come off
2002 S430 rear Rotor removal
I have been working on this for 2 days now. I can't get the rear rotor off does anyone know if I have to remove the rotor center bolt to get the rotor off, if so what size socket is required. Need help asap please getting frustrated.
The only thing holding the rotor on is the small screw. After that is removed just knock it off. Heat and wear can cause the rotor to stick. I hate to say it but "CAREFULLY" use a sledge hammer, and turn the disc while you hit. (CAREFULLY) Its not going to slide off easy.
