crankshaft sensor
Old Jul 27, 2009 | 05:56 PM
ebolick's Avatar
2000 S430, 1999 E 320, 2 K5 blazers,
crankshaft sensor
hey i have to replace the crank shaft sensor, any idea on the cost of this at the shop?
If its a DIY where is it located at?
Old Jul 28, 2009 | 12:03 PM
LAWYER2's Avatar
15' W222
DAFS
Old Jul 28, 2009 | 12:13 PM
ebolick's Avatar
DASF?? what does that mean?
Old Jul 28, 2009 | 01:07 PM
ebolick's Avatar
Anyone know where i can locate the sensor i just ordered it online but have no idea on where it is. I have checked the post but not to much info on where its at.
Thanks for any help you can offer
Old Jul 30, 2009 | 12:07 AM
ajkennedy's Avatar
S500 Silver, Range Rover HSE Black
CPS
It is located underneath the engine bay. If I recall it is accessed from below on the drivers' half of the engine bay and up about half an arm from laying underneath. I have the dealer repair manual on CD at work and I can print out the page to scan to you which shows exactly where it is. I changed it out in about 5 minutes when I did it last year. No problem.
Old Jul 30, 2009 | 11:42 AM
ebolick's Avatar
If you would not mind i would really appericate that, i found some other directions but they are for a ML
Thanks a million
Old Jul 30, 2009 | 12:01 PM
ALLDATAdiy INFO's Avatar
Former Vendor of MBWorld
Mercedes
If you don't have a subscription to ALLDATAdiy.com for your Mercedes I would highly recommend it. I attached an image of the Crankshaft Position Sensor. ALLDATAdiy.com's replacement procedure shows you will only need to remove the air cleaner on the engine side to access the Crank Sensor on your S430. Do yourself a favor and get a subscription. It will be the best $27 you will spend on your car!
Old Nov 10, 2009 | 11:16 PM
Sendmedem's Avatar
2000 S500
I was having the same symptoms as you, stalling or when warmed up wouldn't start for an hour. I changed the cps out a few hours ago. Worked!!
I changed it from the top, I took the intake/engine cover off and reached behind the cylinders from the drivers side. It's a tight fit but I had it done in 10 mins. Your going to need a 1/4inch drive E8 socket to do the fix
Old Nov 11, 2009 | 06:51 PM
giquorag's Avatar
giquorag
This great pictures, thank you for sharing them. I will return to post the picture on this forum and you'll find them great.
