Anyone selling a Door Control Module?
If only the window, I'd say the problem is in the door. If nothing in the door works, could be the DCM has power but has a bad ground. Not likely to be the CAN bus unless both H and L broke; the bus will work with just one wire as a fail-safe. Could be just the window motor or one of the wires to the window motor is broken or grounded (the wires reverse polarity so if one is grounded to chassis the window will roll up but not down; the above-mentioned half-bridge drivers will prevent over-current damage to the DCM).
Will.
So after reading through all these posts about the DCM on my 2000 S500 failing I actually saved mine. To start with, all the lights on the DCM were flashing on and off as were the mirror signals. The windows and drivers seat had a mind of their own not knowing whether to heat up or cool or go up or down. Even the mirrors decided to have an epileptic fit.. Within a few minutes it all stopped with the windows in the up position but non functioning from the drivers door. Nothing functioned from the drivers door. What I did was removed the DCM, mirror control, and window control door modules. I then proceeded to disassemble all three down to the circuit boards and leave them in from of a blow dryer for several hours. I was concerned about the mineral deposits left on the main IC from water so I ran a pin head in between the solder joints to clean the white stuff out. Upon reinstall everything was back to normal. I hope this helps folks in the future. The modules do not deal with water well.
Thanks, good luck.
Cowboy
