Cigarette lighter
Old Sep 17, 2009 | 11:44 PM
ayayikes's Avatar
S 500
Cigarette lighter
I have S500, the cigarette lighter was working until I find out some coins fall in. I removed them and try to charge my cell phone and its not working anymore. I think a fuse blown up and need change. Is that true?
Old Sep 18, 2009 | 01:38 AM
#1dad408's Avatar
W220
Get a light tester out and check for any blown fuses your on the right track.
Old Sep 18, 2009 | 03:39 PM
Corsa9000's Avatar
2004 S55 ///AMG, 2007 E350
The fuse would be the first thing to check and easy to replace if blown, spare fuses are provided by MB on top of the spare tire in the trunk. I am not sure if all three cig lighters (1 front, 2 rears) are on the same fuse. If not, you can use one of the rears to test in the front, if the fuse is not the issue.
Good Luck!
Old Sep 18, 2009 | 07:10 PM
srknutson's Avatar
2004 S500 & 2011 Mini JCW
The coins gave the curcuit a dead short, which means the fuse saved the other electrical bits in your car. FUSE IS BLOWN.
Old Sep 19, 2009 | 04:42 PM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
ayayikes, you didn't give us a model year, but if you cannot locate your fuse diagram, see post 14 and 15 at http://www.benzworld.org/forums/w220...e-chart-2.html (note the error mentioned; on the middle chart, the row labeled F16-F27 should be F6-F27), and also post 3 at http://www.benzworld.org/forums/w220...e-diagram.html.
Your front lighter fuse is probably F11. Rear lighters each also have their own separate fuses.
Old Sep 19, 2009 | 06:11 PM
ayayikes's Avatar
S 500
Thank you guys all It was the fuse. I get it replaced. However when I plug in ipod or cell phone to charge, the car from time to time shakes a little bit and the engine about to cut off. I experience that a few times especially when driving slow in trafic. When I unplug everything it becames normal. I have 97 S500. What could be the problem??
Old Sep 19, 2009 | 10:20 PM
Skylaw's Avatar
You may have done more damage to the wiring than just a fuse. Tough to diagnose just where over the web. You might get better feedback if you post in the W140 forum, which is the one for your car - the W220 is very different. Perhaps someone with a W140 has had a similar problem, and knows which circuit may be affected.
When you plug something into the cigarette lighter it seems to be grounding something it shouldn't, or feeding a voltage where it shouldn't. Removing the device restores normal conditions.
Old Sep 19, 2009 | 11:08 PM
ayayikes's Avatar
S 500
Thank you skylaw. I joind this a bout 3 days now and I noticed that you answer every questions
You are doing excellent job sharing your knowledge. I appreciated. Again thank you
Old Apr 14, 2012 | 04:25 PM
steadystud's Avatar
2003 Mercedes-Benz S500, 2002 Acura MDX Touring
High Feedbacck from speakers when I connect my iphone to the cigarette lighter
Hi Skylaw,
I get high Feed back from my speakers when I connect my iphone to the front cigarette lighter which continues when I use the bluetooth as well. I tried diffeent chargers and the same issue. Apparantly the rear sockets give a light feedback but do not function at all. Can you please tell me how I could solve this by myself?? I would really appreciate it very much.
Old Apr 28, 2015 | 05:01 AM
sohaib99's Avatar
s320
mercedes s320 2003 rear cigarette lighter fuse
hey guys, i have a merc s320 2003 , from last week my rear cigarette lighter is not working . i doubt that the fuse is blown up so how do i change the fuse and where can i find it? thanks all
Old Apr 28, 2015 | 08:37 AM
wallyp's Avatar
2003 S500 2007 GL450
The info has already been given in this thread - read the prior posts...
Old Apr 29, 2015 | 09:33 AM
Skylaw's Avatar
Before assuming it is the fuse, check that the rear window override switch is not activated. It will not only keep the windows from being operated, but will also cut out the rear lighters - a kiddie protective feature covered in your owner's manual.
If you don't have an owner's manual, see https://www.mbusa.com/mercedes/servi...owners_manuals
If you do have one and didn't read it, shame on you!
Old Apr 29, 2015 | 10:21 AM
VMAX7's Avatar
2000 S430, 2000 S500 Both Brilliant Silver!
Skylaw youre the man!
