2.0 droped S 600
what ever I like
![Thumbs up](https://mbworld.org/forums/images/icons/icon14.gif)
this one has 20x9.0 front 20x10.0 rear 245/35/20 and 275/30/20
Perelli Zero tires . rides great ,no rubing, a great handeling car
CLS350
Re: 2.0 droped S 600
what ever I like
that is the set up . and I have had 20x8.5 all around before with 255 perellis and the ride was about the same. the 255 has a bit more side wall.
what ever I like
![Smile](https://mbworld.org/forums/images/icons/icon7.gif)
that is the lowest I would go .
eny lower and you will set the Airmatic or ABC suspension warning light on
then the car will be unsafe and in default mode
also you will damage the upper control arms and shocks .
however I have 30,000 miles on mine with 2.0 drop and no problems at all .....
what ever I like
bear aligment in San Gabriel is the best I have found so far
they are one of the few that can understand how to adjust camber for a lowered car. see Bob
what ever I like
this car has Active Body Control , however the process is the same with Airmatic cars. and Airmatic cars ride better lowered than ABC cars .....
1 Post
2000 S500 Brilliant Silver, 1990 BMW 735iL, 1971 Pontiac Trans Am 455 HO, 1976 Pontiac Formula 400
Ralph, do you know how to lower the Airmatic setting via the MB computer system? It is supposed to be able to be lowered about 1/2 " to be set up like the Euro cars. Do you know where to access this in the Airmatic system? This is about all the lowering I want.
