Aux cooling fan is staying on :s430
I have a 2000 s430. The aux cooling fan is staying on after the car is off,draining the battery. Could this be a module or fuse problem? Where to locate them? This started after the rain. Thanks for any help.
2012 CLS63 AMG Performace - Obsidian Black
Try the fuse links first-
33 and 48. Here's a diagram...
http://www.benzworld.org/forums/w220...e-diagram.html
...good luck
...good luck
I took the fan control unit off & took it apart. There was water & some corrosion. I cleaned it up & put it back. But still the same problem. Could it still be a damaged fan control unit? Should I replace that first?
