Found the source to my problems!
Shane... and everyone else... DONT DO THIS!
NEVER start your benz with a charger hooked to the battery, it can fry the other electronics in your car! You will turn a $100 new battery problem into a $1000 problem.
You should not even jumpstart an Sclass using jumper cables. Batteries should only be charged when DISCONNECTED from the car. Just like I told you here
https://mbworld.org/forums/s-class-w...me-please.html
I hope this is not the case with your car, but prepare for the worse.
just call 1800 FOR MERCEDES
http://www.mbusa.com/mercedes/data/p...e_brochure.pdf
they will come out to you and even install a battery .
No labor charge you just pay for the battery
Or, if you have to jump start, use the Michellin Smart Cables (around US$40), they have surge protection unit built-in and no more black and red terminals, you connect your cables to whatever port on the battery and this Smart Cable will figure it out for you.
I hope this helps.
ps: whats with the dudes over at benzworld???? why they so uptight n whiney all the time?
I hope this helps.
Then you adopted a genuinely offensive attitude when you were called on it. So far you haven't shown the same offensiveness here. You'll get more out of both forums if you don't.
