ABS, ESP and ABC do not work!!
See:
http://www.benzworld.org/forums/w220...error-now.html
http://www.benzworld.org/forums/w220...tic-heavy.html
http://www.benzworld.org/forums/w220...-steering.html
https://mbworld.org/forums/cl-class-...p-install.html
You will need to pressurize the system which bleeds air from the pump by applying about 15 psi (1 bar) into the reservoir and then start the engine. Once you get the fluid flowing and the "level control switch" working, you can bleed the system by raising and lowering the car with this switch. Do you have the MB manual library (shop manual) for this car? You should have it if you are going to do repairs. If you can't get it locally, email me. Good luck.
