TPMS resets itself
Now the TPMS resets itself 5-10 minutes after I start the car. It takes about 5 minutes for the display to restore, which I realize is normal. What the heck could be causing this?
Feel free to comment.
Thanks.
I may have a resolution to my original "reset" problem. I placed the two bad sending units in the trunk at the dealer because I wanted to keep the old parts. They may have been confusing my system and causing it to reset. I removed them from the car just now. I'll post the outcome in a day or two.
Now the batteries are so bad it won't reset; I get the red warning. Time to replace them all (and I'll use the Beru sensors from The Tire Rack when I do).
The entire sensor is replaced, not just the battery. The battery is integral to the sensor. Also, if you buy from the dealer, expect a price over $1K for four. Check with The Tire Rack. The sensors for the W220 are not listed on their website, but they have them, and know exactly what you need - $275 for four (last time i checked).
Next time this happens (and it will on the left side) I'll buy sending units from tire rack and have my local tire shop install them. I was quoted a price of $20 per wheel for installation just yesterday.
If the batteries of the sensors are failing, the sensors will not "auto adjust." They will stay high. As I described above, if you drive with the high reading and it comes down as your tires heat up, it's a very good indication your sensor battery is failing.
After TPMS has reactivated and calibrated itself, you should see pressures close to 29 and 32 (perhaps slightly higher; it depends on how long the reset takes, and how fast you drive). Importantly, the front tires should be close to one another - within a pound - and so should the rear tires. The fronts and rears will still differ. If they system has calibrated properly, on your next cold start, the system will read 29 front, 32 rear.
Once you have done this calibration, you should be able to inflate your tires to your preferred pressures, and the readings should be accurate on the TPMS.
If your system shows things differently, you either have a sensor problem or a controller problem. As the posts above reflect, an initial (cold) reading that is significantly higher than actual pressure is a good indication of a failing sensor battery - especially if the high pressure reading pressure comes down as you drive (in a normal system, the pressure would go up, not down, as the tire warms up).
Those are my thoughts, and that's about all I can say - except that this was pretty much covered in the W220 Owners Start Here sticky, in the TPMS links.
each plus tax and shipping, total was $420.
I have to say for people who pay attention to their tire pressure and check them regularly, TPMS has a lot of unnecessary hassle. Didn't they become mandatory when all those Ford Explorers were tipping over due to low tire pressure?
that they cannot work
the valve stems are too short. They did not seem to have much experience with this type. I had to go back into the work shop and show him how to adjust the angle for it to fit which it did
. After replacing all 4 I did the re-activation and drove, and drove and re-activate, on and on etc nothing working. I went back to the shop and collected the old parts and guess what I did, I put them in the trunk and the system got worst. Reached home frustrated and went to this forum and remembered, Oh foolish one, it's reading the old ones in the trunk, took them out re-check the pressure and WHOA!!!
works fine. I checked the pressure this morning cold and they read exactly what my mechanical gauge reads.
