Car vibrates passed 60 mph
Old Oct 17, 2010 | 10:04 AM
215mbs430's Avatar
2001 s430 200k miles
Need help with this one. I put on brand new tires with alignment got my brakes done and I still feel vibrations passed 60 mph. Also I feel creaking when I turn the steering wheel could this be related
Old Oct 17, 2010 | 11:14 AM
xexpo's Avatar
2000 S430 140k (07/11)
Check front suspension ball joints and bushings.
Old Oct 17, 2010 | 01:18 PM
manano's Avatar
S350 2005
it's definitely the bushings ... i had the same problem ... car purrs now set me back by $350 ... but it was well worth it ... especially if you're planning to keep the car ..
Old Oct 17, 2010 | 03:35 PM
215mbs430's Avatar
Thanks for your help. It was getting annoying on the highway.
Old Oct 17, 2010 | 09:02 PM
ajkennedy's Avatar
S500 Silver, Range Rover HSE Black
Vibration on Highway
Sorry to muddy it up, but for me it was the U joints.
Old Oct 22, 2010 | 01:26 PM
Oxygen's Avatar
W220 S65 AMG
What's a U joint?
Old Oct 22, 2010 | 04:25 PM
xexpo's Avatar
It's a type of "joint" but can't be smoked..
Old Oct 22, 2010 | 05:47 PM
Trinsoca's Avatar
2005 S500
Originally Posted by Oxygen
What's a U joint?
It is short for Universal Joint which is part of the drive shaft. A one piece drive shaft will have 2 u-joint and a 2 piece will have 3 u-joint etc, etc. It allows the drive shaft to operate at different angles.
Old Oct 22, 2010 | 08:32 PM
xexpo's Avatar
Trinsoca: I think Oxy was being sarcastic.
AjKennedy: Did you have to replace the rear drive shaft? I don't see the U joints being available alone, at least I don't see a part number. Please advise. Thanks.
Old Oct 22, 2010 | 09:58 PM
215mbs430's Avatar
So you guys are leaning more towards bushings or ball joints or the U joint?
Old Oct 22, 2010 | 10:26 PM
xexpo's Avatar
Year and mileage of your car would be good to know.
You mentioned at your first post that there is some creaking when you turn the steering wheel as well. Possibly related or perhaps multiple problems.
You jack up the front wheels and try moving the wheel side to side to see if there is a movement. If there is, try locating where the movement is. I would pay special attention to the outer tie rod ball joint.
Inspect bushing on the front lower arm, look for cracks in the rubber and see if the bushing and of the arm is rubbing at the bracket it is bolted to.
The vibration at 60+ could be several things.
Again, do some visual checking and try to eliminate things. Check both front and rear flexible joint discs at both ends of the propeller shaft for cracks, also the rubber boot bearing at the middle of the propeller shaft for a visible damage. Also take a look at the transmission mount for visible damage and cracks.
Old Oct 23, 2010 | 03:21 AM
ajkennedy's Avatar
U joints
http://cgi.ebay.com/ebaymotors/Merce...-/270648069726
Old Oct 23, 2010 | 01:19 PM
xexpo's Avatar
Ah ok, the flex joint disc.
Old Oct 24, 2010 | 11:10 AM
215mbs430's Avatar
My car is a 2001 s430 with 208,000 miles.
Old Oct 24, 2010 | 06:32 PM
215mbs430's Avatar
One more weird thing happened. I put my parking brake on and after I released it I got a BAS, ESP, Airmatic malfunction warning on
Old Oct 25, 2010 | 10:49 AM
Oxygen's Avatar
W220 S65 AMG
No sarcasm at all... I never heard that term. Thanks for the explanation!
Old Oct 25, 2010 | 10:50 AM
Oxygen's Avatar
W220 S65 AMG
Is this the something as a guibbo (sp?) ?
Old Oct 25, 2010 | 01:52 PM
Arnee's Avatar
Cayenne GTS, Cayenne Turbo
same thing as the Guibo, same thing as the flex disc
Old Oct 25, 2010 | 09:12 PM
nachilus's Avatar
09' GL550, 05' S55 (sold), 04' Yukon Denali XL, 05' 745il (sold), 01' 740il (sold)
Please do not mention GUIBO, it drives me crazy when I had the 05 745.......
Old Oct 25, 2010 | 09:20 PM
Oxygen's Avatar
W220 S65 AMG
Here's a hairy one...
Old Oct 26, 2010 | 12:20 AM
Arnee's Avatar
Oh yes, my M3's guibo had to be replaced too.
Old Oct 26, 2010 | 01:11 PM
tusabes's Avatar
Mercedes
wow that thing needs to be shaved!!
Old Oct 27, 2010 | 10:06 PM
Arnee's Avatar
I hear that!
Old Nov 1, 2010 | 06:51 PM
damastah's Avatar
2000 s500
could it be? your wheels need to be balanced. ?
Old Nov 4, 2010 | 01:39 PM
xexpo's Avatar
Now I know why he sold the car.
It was just too darn hairy between the legs!
