Please i need some Tech help Car is not cranking?
The car is sitting on all 4 wheels. The car doesnt crank at all. the air compressor doesnt go on and the car doesnt rise.
The lights work and the remote opens and closes the car but the windows dont go up or down with the ignition in the on position. And the Instrument cluster doesn't go on. The cluster only lights up when you open the car door.
Does anyone have any experience with this because i know there must be guys out there with similar problems.
Also is there a location on the car that i can pump with a compressor or somthing to rise it up?
Lights will go on some items will operate but it need full power to start or it won't crank.Make sure you charge it with the key out of the ignition.
Might not be the issue but it is a good place to start the process.
mercedes roadside assistance came... they really do not know anything about these cars. Even had a tech that came from local close by dealership but i was pretty dissapointed it was little kid coming from local tech school that have no experience.
car cannot be towed it is on a angled driveway touching the floor on all four wheels and front bumper is mm's from the floor also.
is there any fuses on the left or right side of the car that i should check?
Was the battery replaced by the RSA team just recently?
Year and mileage?
I had the Head dealer technician come to look at the car today. he brought the computer hooked it up and it told him everything was fine. The guy was completely puzzled. He said it had to be towed back to the shop to use the main computer that uses internet connection to diagnose it. They tested all the fuses and everythings working.
The only problem is the car cannot be towed at all. It is on a incline driveway sitting on all 4 rims and the sideskirts. the front bumper is couple mm's from the floor.
Tow truck guy came the other day and said he wouldnt even attempt to touch the thing.
http://www.griotsgarage.com/product/in+your+garage/jacks+%26+stands/set+of+two+rolling+hydraulic+car+lifts.do
http://www.europeancarweb.com/auto_tools/0211ec_tool/index.html
How about trying this trick to raise it for transport:
http://www.benzworld.org/forums/w220-s-class/1547183-how-fix-w220-airmatic-strut-6-a.html
Harborfreight carries nice units for a fraction on the griots.
Don't see what year the S is but does it have an aux battery?
if so has it been checked?
