Guys I need help/input on this!!
Old Jun 24, 2011 | 06:46 PM
MBNiko's Avatar
2006 C55 AMG, 2005 E55 AMG
So just today as I was starting my car to leave work, it hesitated a lot while I turned the key to start it. It took about 4 seconds of kicking before it fired up. When I got home ( and installed smoked bumper lights) I wanted to start it again but this time all it did was kick and NO start...... Could it be my spark plugs? What could this be??
Old Jun 24, 2011 | 06:54 PM
shoot_da_breeze's Avatar
2003 Jaguar XJR, 2000 S500
Try charging your battery see what happens it should fix this. Goto autozone they do it for free should take about an hour.
Old Jun 24, 2011 | 06:59 PM
MBNiko's Avatar
My battery was dead about two weeks because I left the fog lights on. I took it to Autozone and they charged it there for an hour. I wonder if the battery is losing its juice?
Old Jun 24, 2011 | 07:16 PM
Quadcammer's Avatar
96 and 08 911 turbos
battery is done.
buy a new one
Old Jun 24, 2011 | 07:21 PM
MBNiko's Avatar
Originally Posted by Oliverk
battery is done.
buy a new one
Could always rely on Oliver for a suggestion
Thanks for your input too Shoot, good call. Im gonna head there now, hopefully this is the issue.
Old Jun 24, 2011 | 11:02 PM
they can test your battery and tell you if thats the problem. Even when your battery starts going bad when you turn your car on it should charge it because the voltage goes up to 14volts. have them check your alternator too. they should be able to with a multi meter that they have.
Old Jun 25, 2011 | 03:06 AM
MBNiko's Avatar
Bad news guys........ its not the battery. I started it one time and it started to die on me, idling very very rough. What could this be?
Old Jun 25, 2011 | 05:20 AM
tusabes's Avatar
Mercedes
the BATTERY.
Unlike many other cars, The w220 mercedes car will not run correctly with a weak battery, it is very sensitive.
Change the battery first. Autozone and other places may even let you return it, if its not the problem.
Old Jun 25, 2011 | 10:00 AM
MBNiko's Avatar
Originally Posted by tusabes
the BATTERY.
Tusabes I took it to Autozone, the battery checked out perfectly, had 12.6 volts.
Old Jun 25, 2011 | 12:13 PM
Quadcammer's Avatar
Whats the voltage when the car is running?
Old Jun 25, 2011 | 02:03 PM
Check the voltage when the car is running if its under 14v then your alternator is bad!
Old Jun 25, 2011 | 03:14 PM
MBNiko's Avatar
UPDATE*** As it turns out my fuel pump and regulator were bad! I got them changed this morning and.........she started up better than ever This was my first issue with my S430 and I just hit 100k miles last week.
Old Jun 26, 2011 | 03:42 AM
tusabes's Avatar
Mercedes
Thanks for the update and the fix.
Still, 12.6 is not very good for the battery. A strong, fresh battery is 13.2 when car is off, 14-14.5 when car is on.
Check the date code on the battery and if its more than 5 or so years old, change it.
