Retrofitting Bi-xenons to a Xenon 2000 S500
Old Jun 16, 2003 | 02:31 PM
GMW's Avatar
GMW
2013 ML63 AMG PP
Question Retrofitting Bi-xenons to a Xenon 2000 S500
Need help/advise on how to make the New Bi-xenons work on the old Xenon system. I have attached pics so that you can see the dilema. Old has two sockets of which one is squarish. The newest light has three sockets of which only one (i believe the main power socket) is the same as on the old light.
So please let the advise or better yet, the solutions flow!
Attached Thumbnails Retrofitting Bi-xenons to a Xenon 2000 S500-old-xenon-light.jpg
Old Jun 16, 2003 | 02:37 PM
GMW's Avatar
GMW
2013 ML63 AMG PP
Question the new one
the new one with complimentary 3 sockets! I believe one of the outer two sockets is a range adjuster and the other the shutter control for the bi-xenon bulb/light. Not sure which is which yet. The center socket is similar if not identical to the one for the Xenon light.
Attached Thumbnails Retrofitting Bi-xenons to a Xenon 2000 S500-new-bi-xenon-light.jpg
Old Jun 16, 2003 | 03:11 PM
mercsd's Avatar
Porsche Carrera 2008
Lightbulb
Try contacting the author of the following publication:
http://www.mbnz.org/publications/pub.asp?id=67
He may be able to shed some light on your problem
Old Jun 20, 2003 | 07:18 AM
CarlssonCRS's Avatar
r171
its possible. my friend did it
Old Jun 21, 2003 | 04:37 PM
AMGLAB's Avatar
2012 CLS63
There are three different connection points. The 6 pin connection is a direct plug for the lights' power. The square 4 pin connector is for the self leveling connection and needs to be replaced with an in-line 4 pin connector. This is available from MB, and the old wire pins just need to be inserted into the new straight line connector. The three pin connection point on the new lights should be the same as the old and is used for grounding.
Old Jun 27, 2003 | 02:08 PM
Dizzy's Avatar
Mercedes S430 '00
Please see the link below:
https://mbworld.org/forums/showthrea...hlight=bixenon
A custom made conversion unit was built to handle the conversion.
Dizzy
Old Jun 28, 2003 | 12:45 AM
Crankin's Avatar
2000 S500 Brilliant Silver, 1990 BMW 735iL, 1971 Pontiac Trans Am 455 HO, 1976 Pontiac Formula 400
But I don't think Anssonnn ever followed up with the completed projest.
Performance parts sells the lights and says they include an adaptor that you need to splice in. Would like to see a success story on this.
Old Jun 28, 2003 | 12:52 AM
r171
dude.... did you guys read what i wrote.... its possible to change the lights. my friend did it and it wasnt that hard!!
Old Jun 28, 2003 | 08:04 PM
vraa's Avatar
We understand that, but it's just a line stating that it works. No pictures or more information was submitted.
Old Jun 28, 2003 | 11:38 PM
r171
well if any of you want it done and happen to be in LA. you can PM me for the info on where to do it. my friend did it to his car, you can take a look at it on ebay:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2421007399
